VintageRice Posted January 5, 2012 Author Report Share Posted January 5, 2012 I have been wanting to do the same thing. Some things I have found. the KA24e head has the mount for a mechanical fuel pump from the L motors. The cam lobe that pushes the pump can be unbolted from the L cam and installed on to the KA cam, you will need a 3psi reg. As far as intake manifold goes, I haven't desided if it would be better to build an adaptor onto the lower hald of the manifold and not have to worry about the coolant passage, or build from the head. As far as air flow it looks like an R1 1liter at 14000 rpm should be about the same flow as a 2.4 KA at 5800 rpm? I hope there would be room to push higher. Good luck on your build. Please post updates, I need moto-vation :D . Does anyone have more info on converting the ka24e to use a l-motor mechanical fuel pump? I like this idea for its cheap/reliability factor. :) Quote Link to comment
VintageRice Posted January 7, 2012 Author Report Share Posted January 7, 2012 TTT for my Question. Quote Link to comment
VintageRice Posted February 15, 2012 Author Report Share Posted February 15, 2012 So?? Does anyone know if that actually works? If you CAN in fact take the fuel pump lobe off the L-series cam and put it on the Ka can, mill out the mount and use a mechanical l-series fuel pump on a SOHC Ka24e ??? Quote Link to comment
VintageRice Posted February 23, 2012 Author Report Share Posted February 23, 2012 Picked up the fuel pump love of a l16 at pick-n-pull today. Compared it to my ka24e cam and it's the wrong diameter and threads on the bolt. So unless there's a diff one or can make a little spacer bushing I don't see how this will work. Kinda feel like I'm talking to myself here. Don't make me start another thread on this subject!!! :D. Anyone tried this?????????????? Hello ???????? Quote Link to comment
datsunfreak Posted February 23, 2012 Report Share Posted February 23, 2012 Might try to search for a fuel pump from Mexico? Why can't you put the lobe from the L-series on the KA cam? You don't use the L-series bolt. You just take the bolt off, slide the lobe on, and put the bolt back in. And I'd bet cash money no one has tried this. :P You can buy a good electric pump for $40. Putting the L-series pump on sounds like $60 worth of hassle to save $40. ;) Quote Link to comment
VintageRice Posted March 5, 2012 Author Report Share Posted March 5, 2012 Updates. Bought a 11.5 lb flywheel. Heads going to the shop today. And here is pics of the crossmember flip. http://community.ratsun.net/topic/26131-speedy-a-1970-2dr-510-project/page__st__ Quote Link to comment
VintageRice Posted March 11, 2012 Author Report Share Posted March 11, 2012 Put the rotating assembly and timing set together today!! Getting closer!! Honing Crank Bearings Rings Scary Andrew Piston time! Delicious! Tappy Tappy, tap tap a lappy What the He!! did you do with the.........oh here it is. The Aftermath Important stuff done......more to come Quote Link to comment
jesusno2 Posted March 11, 2012 Report Share Posted March 11, 2012 All that work and a crusty head slammed back on it. :rolleyes: Quote Link to comment
Sinnful Posted March 11, 2012 Report Share Posted March 11, 2012 All that work and a crusty head slammed back on it. :rolleyes: Haha sorry but I was thinking the same thing, brake clean doesnt cost that much and does wunders Quote Link to comment
VintageRice Posted March 11, 2012 Author Report Share Posted March 11, 2012 He just brought the head that night from the rebuilder. We were in a hurry, the insides look nice. I'll clean it on there. Nobody PANIC !! Quote Link to comment
jesusno2 Posted March 11, 2012 Report Share Posted March 11, 2012 I would think that if the head was rebuilt they would taken the time to tank it and bead blast it? weird. sorry but when rebuilding a engine clean is king! Quote Link to comment
VintageRice Posted March 12, 2012 Author Report Share Posted March 12, 2012 When rebuilding MY DATSUN engine budget is king. :) The head was fine. He replaced 4 bent valves and all the seals. Then surfaced it. I got a SMOKING deal. Just payed for parts. (THANKS JOBY) so I'm ok with cleaning the outside myself. I knew I shoulda cleaned and painted it BEFORE I posted pics. Lol o well........ :D 1 Quote Link to comment
VintageRice Posted March 14, 2012 Author Report Share Posted March 14, 2012 Put more together today. Also got my Matchbox L-series Dizzy all mounted up. Tapped one hole and built a bracket for the other. All timed and ready to go. Por-15'd the bay before install. Quote Link to comment
VintageRice Posted March 14, 2012 Author Report Share Posted March 14, 2012 BTW if anyone is wondering I threw the stock cam back in for now. Want to get it running and get a tuning baseline. Then when funds allow I'll do a cam swap. Most likely the Stage 2 O&J. Quote Link to comment
VintageRice Posted March 23, 2012 Author Report Share Posted March 23, 2012 Motors in!! Quote Link to comment
chebetio510 Posted March 23, 2012 Report Share Posted March 23, 2012 im slow... so bare with me.. So u are using the match box dizzy from the lserie.. for example l18 and oil pump.. and by doing this u got rid of the wiring headache technically.. right? u just need. power to the distributor as in a l series? and by using the r1 carbs,.. are you gonna use a management like mega squirt? or just add gas,, and tune? lol Quote Link to comment
banzai510(hainz) Posted March 23, 2012 Report Share Posted March 23, 2012 ??????????????????????? why would carbs need a mega squirt? matchbox dizzy? blk/wht wire(key ON wire) Quote Link to comment
VintageRice Posted March 23, 2012 Author Report Share Posted March 23, 2012 im slow... so bare with me.. So u are using the match box dizzy from the lserie.. for example l18 and oil pump.. and by doing this u got rid of the wiring headache technically.. right? u just need. power to the distributor as in a l series? and by using the r1 carbs,.. are you gonna use a management like mega squirt? or just add gas,, and tune? lol *facepalm* I'm sorry...... Don't want to be mean or rude but.........omg........someone else help this man. Quote Link to comment
datsunfreak Posted March 24, 2012 Report Share Posted March 24, 2012 The head was fine. He replaced 4 bent valves and all the seals. Then surfaced it. I got a SMOKING deal. Just payed for parts. Any particular reason you're using a truck head instead of a 240SX head? Sorry if you already covered that. Quote Link to comment
VintageRice Posted March 24, 2012 Author Report Share Posted March 24, 2012 What?!? Who said it was a truck head? Quote Link to comment
chebetio510 Posted March 24, 2012 Report Share Posted March 24, 2012 I only ask because of this link... http://en.wikibooks.org/wiki/Nissan_240SX_Performance_Modification/KA24DE_and_KA24E/ITB's So chill with the face palms . Lol Quote Link to comment
VintageRice Posted March 24, 2012 Author Report Share Posted March 24, 2012 The matchbox dizzy controls the ignition. The carbs control the air/fuel. No need for a management system. Quote Link to comment
datsunfreak Posted March 25, 2012 Report Share Posted March 25, 2012 What?!? Who said it was a truck head? It's got the "Hecho en Mexico" stamp on it. That's usually only on truck heads? All the car heads I've seen don't have it. Quote Link to comment
VintageRice Posted March 25, 2012 Author Report Share Posted March 25, 2012 It's got the "Hecho en Mexico" stamp on it. That's usually only on truck heads? All the car heads I've seen don't have it. I had no idea my head may be a truck head. If it is I'm going to be seriously irritated!! Whats the diff between the truck head and the car head? I diff cam I assume but are the port sizes the same? Can anyone confirm how to tell if its a truck or car head?!?!?! Datzenmike Where you at?@!!? Quote Link to comment
datsunfreak Posted March 26, 2012 Report Share Posted March 26, 2012 I had no idea my head may be a truck head. If it is I'm going to be seriously irritated!! Whats the diff between the truck head and the car head? I diff cam I assume but are the port sizes the same? Basically, that. Slightly different cam, same ports, and what country it was cast in. Truck heads are made in Mexico, and I believe the car head is only made in Japan. Some of the racers I know refuse to use the truck heads, claiming the Mexican castings are inferior. Doubt it makes a difference on a street car though. Can anyone confirm how to tell if its a truck or car head?!?!?! Truck or not, it's Mexican. Or it wouldn't have the mark on it. Quote Link to comment
