NWOleman Posted June 27, 2011 Report Share Posted June 27, 2011 So i'm looking to get ahold of this guy to find out about his ignition system. He has the EDIS 4 with the megajolt setup which is what i want to run in my goon. I think he is from Arkansas. He has pictures from and stuff of his pickup on the Autosportlab website and his name on there is Ratsun so i figured he would be on here. Thanks for the help guys! Quote Link to comment
Hardwyre Posted June 27, 2011 Report Share Posted June 27, 2011 I'm running an EDIS 6 through my Megasquirt on my 280Z. What do you want to know? Quote Link to comment
NWOleman Posted June 27, 2011 Author Report Share Posted June 27, 2011 how do i get the the correct map setup for my motor? Quote Link to comment
NWOleman Posted June 29, 2011 Author Report Share Posted June 29, 2011 Found out who this guy is in case anyone was wondering. It's Burleigh. Quote Link to comment
Hardwyre Posted June 29, 2011 Report Share Posted June 29, 2011 how do i get the the correct map setup for my motor? There's really not a correct map for any motor. Various forums should be able to help you find starter maps, but then it comes down to tuning it. If you have an idea where timing should be under certain loads and RPMs, you can pre-set your timing (usually pull a couple of degrees to safety's sake) then have someone drive her while you adjust the fuel map. Another option is see if you can location someone who's got experience with dyno tuning the megasquirt. Where abouts are you located? Quote Link to comment
NWOleman Posted June 29, 2011 Author Report Share Posted June 29, 2011 I'm in tillamook oregon. ggzilla and datzenmike have been helpin me in the general technical section. the thread is under ignition curves i think? forgot what i started it under. thanks for the input hardwyre! Quote Link to comment
NWOleman Posted June 29, 2011 Author Report Share Posted June 29, 2011 its under Factory service manual? advance curves. Quote Link to comment
FoxyRoadster Posted June 30, 2011 Report Share Posted June 30, 2011 I've got MJ on my vw and you might also end up adjusting the factory curve a bit so be careful after getting the factory settings in. Also since your car is carbed you shouldn't have to touch your mixture any if you already have it dialed in. If you go with megasquirt and do EFI a wideband o2 will be your new best friend. Quote Link to comment
Hardwyre Posted June 30, 2011 Report Share Posted June 30, 2011 I mounted my Innovate digital blue LED 02 gauge in the pod from the old clock on my Z. It damn near looks like it's factory. Wideband is SO much nicer than narrowband. One of the things you can do is build a pair of Det Cans. These, when build right, can so a GREAT job of helping you hear detonation. You might want to pop over to MSEXTRA.com and check out the forum and see if anyone has a vehicle similar to yours with a map you can start from. Quote Link to comment
FoxyRoadster Posted June 30, 2011 Report Share Posted June 30, 2011 Also forgot to mention this, if you haven't messed with soldering electronics before I'd really suggest buying prebuilt. It took me a while and I did not enjoy it as much as the for fun electronics kits I've done in the past. Quote Link to comment
ggzilla Posted June 30, 2011 Report Share Posted June 30, 2011 Sadly, MJLJ is no longer available in kit form, so no more cheap solder-your-own specials. Brent said they stopped making the mini-sized CPUs and now only make the nano-sized one which are difficult for hobbyists to solder. So now MJLJ is $161 pre-built Or you can use MegaSquirt II at $266 kit form Quote Link to comment
