thumperky Posted June 22, 2011 Report Share Posted June 22, 2011 Fronts - Panasports 15x6 et 22 with Toyo T1S 195/45/15 Rears - Panasport 15x7 et 22 with Toyo T1S 195/50/15 Rolling shot @ GG 2011 Rims and tires have less than 5k on them.. the rears are worn a bit more due to camber and the occasional loss of traction.. ;-) Center caps included.. Rear tires rubbed a bit when i swapped to disc brakes.. had to use a 8mm spacer to clear the caliper instead of a 12mm to not rub with stock camber.. was going to swap rear tires side to side to help tire wear and have a new sidewall.. depends on what buyer wants.. FYI front setup is 280zx struts with coilovers & Wilwoods.. no spacer.. Price - $1400 plus shipping.. Let me know your area code so I can get you a quote.. Link to comment
banzai510(hainz) Posted June 23, 2011 Report Share Posted June 23, 2011 Man I would keep them. Ratsun people dont have money . Might be able to get 800$ for them but on the 510realm , But just because the tires you got are expensive also. Perfect offset. Hopefully a high roller will get these. The last set of Pansaports I had took a while to sell and that was 500$ with Z car tires on them. Link to comment
thumperky Posted June 24, 2011 Author Report Share Posted June 24, 2011 yeah i have them on the realm already.. just posting on here to get the word out.. if they don't sell right away, that's fine.. they will sit in the garage until they do.. thanks for the bump.. ;-) Link to comment
thumperky Posted July 5, 2011 Author Report Share Posted July 5, 2011 Happy 4th of July!! Link to comment
Austinlwalker Posted November 17, 2011 Report Share Posted November 17, 2011 still have the rims? Link to comment
