jimmy dale Posted June 4, 2011 Report Share Posted June 4, 2011 ok i got it in had to cut the bracket used the 2 bar system as shown by other post when i put the battery in one of the excisting wires had power so i hooked it to the alt / lined up runs good all done and the lights are still dim what else do i need to do i am takeing it to napa tomorrow to have it tested for how much charge i will let you know Quote Link to comment
Wide14u Posted June 4, 2011 Report Share Posted June 4, 2011 i think you have to bypass the voltage regulator have you done that yet Quote Link to comment
jimmy dale Posted June 4, 2011 Author Report Share Posted June 4, 2011 no i only hooked up the the white wire to the back of alt it was the only wire with power when i hooked up the battery and the volt reg is unpluged lol all new to me but i am trying Quote Link to comment
jimmy dale Posted June 4, 2011 Author Report Share Posted June 4, 2011 when it was running i unhooked the battery terminal and it still ran i think thats good Quote Link to comment
Wide14u Posted June 4, 2011 Report Share Posted June 4, 2011 http://.ratsun.net/topic/28103-removing-voltage-reg/ look here Quote Link to comment
nismo dr Posted June 4, 2011 Report Share Posted June 4, 2011 you have to jump wires on the regulator plug, unplugging it won't do it. Quote Link to comment
Wide14u Posted June 4, 2011 Report Share Posted June 4, 2011 some one make that into a link Quote Link to comment
Wide14u Posted June 4, 2011 Report Share Posted June 4, 2011 http://.ratsun.net/t...ng-voltage-reg/ look here click on this Quote Link to comment
nismo dr Posted June 4, 2011 Report Share Posted June 4, 2011 http://community.ratsun.net/topic/28103-removing-voltage-reg/%20look%20here doh. a day late and a dollar short Quote Link to comment
Wide14u Posted June 4, 2011 Report Share Posted June 4, 2011 http://community.rat.../%20look%20here doh. a day late and a dollar short thanks i couldnt do it Quote Link to comment
Wide14u Posted June 4, 2011 Report Share Posted June 4, 2011 i hope this helped Quote Link to comment
nismo dr Posted June 4, 2011 Report Share Posted June 4, 2011 a picture is worth a thousand words Quote Link to comment
yello620 Posted June 4, 2011 Report Share Posted June 4, 2011 Original poster, are you talking about using a G.M. one wire alternator? Have you done any research about those pieces of crap? Must not have if you are wondering why your headlights are dim at idle. They are crap. Quote Link to comment
jimmy dale Posted June 4, 2011 Author Report Share Posted June 4, 2011 ok i have a flip video how do i post videos here or i can take snapshoots off it and post them but how? Quote Link to comment
kelowg Posted June 4, 2011 Report Share Posted June 4, 2011 the one i got from z theropy, just ran batt cable directly to battery, another heavy ga wire to ground. using factory wire u need jumper wires on volt reg plug like shown on dime quarterly. but truck wiring is different. remember,it need right rpm to switch on the gm unit. something over 800rpm, if i remember right. Quote Link to comment
vidalia Posted June 4, 2011 Report Share Posted June 4, 2011 thanks for the help, he is trying to figure out the pic in the link our reg has six wires the pic shows 4..... Quote Link to comment
vidalia Posted June 4, 2011 Report Share Posted June 4, 2011 ok he hooked all the hot ones together and the grounds together as tested with light tester with key on will try to get pic.... Quote Link to comment
vidalia Posted June 4, 2011 Report Share Posted June 4, 2011 ok now the charge light stays on when the truck is off, and the temp gauge is hot..... Quote Link to comment
vidalia Posted June 4, 2011 Report Share Posted June 4, 2011 ok got it had to ground the alternator to three things just for future reference: 6 wire regulator 620 red/white, blue/white wire together, yellow and white wire together, black wire has to be grounded to the battery. white wire with blk stripe unhooked. alternator: white wire/red stripe hooked to the back of alternator, alternator is grounded to frame and battery. it runs and charges no bogging down when lights and heater are turned on....... Quote Link to comment
vidalia Posted June 4, 2011 Report Share Posted June 4, 2011 pics: *The wire nuts are there for temporary purposes to make sure it all works* Quote Link to comment
ggzilla Posted June 4, 2011 Report Share Posted June 4, 2011 Sounds like your ground was non-existent, so make sure both the block and body are grounded. the alt is least of yo problems for poor ground, burning the wiring is worst case. 1 Neg battery cable to block 2 neg batttery wire to body, usually to horn bolt Quote Link to comment
jimmy dale Posted June 8, 2011 Author Report Share Posted June 8, 2011 ok is it possible for alt to drain battery hooked up directly Quote Link to comment
jimmy dale Posted June 21, 2011 Author Report Share Posted June 21, 2011 ok well the only thing not grounded is the winshield lol seems to be working fine will have to build a tightner keeps working belt lose and wont charge might try the turnbuckle idea but now i will be putting a slave cylinder on it only comes out half way and lost clutch hopeing i dont have to replace clutch yet or i will go with the 5 speed trans and rearend Quote Link to comment
