Logical1 Posted June 1, 2011 Report Share Posted June 1, 2011 I have become quite the collector of L series transmissions lately and thought it would be a good idea to brainstorm on some tests for a used transmission when you pull one at a yard or buy one from parties unknown. Here is my list of easy first checks: 1. Grab in the input shaft, turn & shake it to check for 'play' in the bearings. If it wobbles up,down,left,& right front bearing is not in good shape. Harder to do in the back a much lesser problem but still kinda possible. 2. Twist the input shaft and listen for 'grinding' 'scratching' or stiff spots. 3. Bring a shift lever with you and run the tranny through the gears to see how the 'click' If you dont have a extra shift lever you can use 2 screwdrivers in a pinch, one through the eye holes as a fulcrum and the other as the actual lever. 4. If it has fluid, drain into a clear plastic tub and look for metal 'bits, bobs, & chunks' Also inspect the drain plug magnet for how much 'metal fuzz' is stuck to it and how big the particles. Bigger particles is ummmm bad ;) 5. Visually inspect the 'seals & seams' and any obvious leaking points along the tranny for oil smears and stains. Dry trannys are happy girls! 6. I made a transmission drill adapter so I could fill up a tranny with fluid while out of the car and 'drive it' with the drill to listen for any gear whine and test gear mesh while spinning. Looks like this: There has to be some other 'Ratsun' tests I'm leaving out! I am trying to focus on tests you can preform while the transmission is whole. Breaking into the tranny is a whole other adventure! Quote Link to comment
kmc63 Posted June 1, 2011 Report Share Posted June 1, 2011 Sounds like I should try to get your asistance when im ready to go get one. Which will probably be soon. Quote Link to comment
