usmc210 Posted May 26, 2011 Report Share Posted May 26, 2011 just bought a 69 510 in amazing condition, however it runs not so well. I was wondering what to do with this specific engine to make it run smother. It wants to die while running until it gets warm, and still cuts out every little bit. Has an automatic. It has new spark plugs and wires and the car only has 737xx miles on it. Any help would be amazing. p.s. I did some searching around -Shawn the car after restoring the paint on the hood Quote Link to comment
izzo Posted May 26, 2011 Report Share Posted May 26, 2011 Carb may need a rebuild. Try tuning it first, if you don't know how have someone that knows how do it. Plugs, wires, points etc may help too. as well as getting the vavles adjusted. Quote Link to comment
banzai510(hainz) Posted May 26, 2011 Report Share Posted May 26, 2011 crap these nice stock 510s keep showing up. KEEP IT STOCK!!!!!!!!!!with the hubcaps!!!!!!!! olddatsuns.com for information. EZ cars to maintain, I havent dealt with automatics myself. I heard you time them in gear w brake on. get a Haynes manual at least ans start reading Quote Link to comment
jun Posted May 26, 2011 Report Share Posted May 26, 2011 It's nice to see a stock 510. I've thought about putting my wagon back to stock at times, hubcaps and all! Quote Link to comment
usmc210 Posted May 26, 2011 Author Report Share Posted May 26, 2011 got my haynes manuel, idk if i want to keep it stock . Going to work on it this weekend some. Noticed my air-pump/ emissions control device is not connected. Would that cause to the bad idle? Quote Link to comment
izzo Posted May 26, 2011 Report Share Posted May 26, 2011 If there is a vacuum leak, maybe. One of the rubber nipples i put on my 720 intake popped off, it had a ruff idle too, till i gave it some gas. Quote Link to comment
banzai510(hainz) Posted May 27, 2011 Report Share Posted May 27, 2011 KEEP IT STOCK if truly stock you can get more $$$$ Once cut into I always pay less Is there a vaccum line to the trands to tell it to shift? Time it in gear first and see if that helps. People who own auto would know more like Datsunaholic Quote Link to comment
