hows ur truck rev?
Siqx20
Funny question I kno. I installed a tach in the truck. Im used to hondas that can rev to the moon. My truck idols at a lil under a grand. But when driving it revs to about 3-4 before I feel like I shouldn't push it to much harder. Its a tired motor. I have a l20 all stock with a 5 speed. Stock rear end. Everythig sound normal?
  • Replies 11
vacuum 2ndary stuck on the carb????????
time correctly
ck cam timming
this is all free to ck.
olddatsuns.com
I know my secondary opens. I will check timing. I don't have a timing light but I can check my timing marks im sure. My ignition timing will be tricky I imagine without a light. But thanks I.will check these.
I have a L16 in a truck and it revs alot better then the L20b in my other truck. Its probably because the L16 has a shorter stroke and smaller pistons. The L16 seems to me to have more power in the top end and the L20b has more torque in lower rpm's. These are both stock motors with stock carbs.
