Mini-L320 Posted May 25, 2011 Report Share Posted May 25, 2011 Heres my L18 Suck-threw Turbo Setup, which most likely will be in my 210 soon if I can get the tranny fixed. Quote Link to comment
Mini-L320 Posted May 25, 2011 Author Report Share Posted May 25, 2011 Did the L18 come from the Factory with Dual Points Distributor? Quote Link to comment
The datsun kid Posted May 25, 2011 Report Share Posted May 25, 2011 umm did you buy that like that?? cuz you sir are making me jealous :lol: Quote Link to comment
Mini-L320 Posted May 25, 2011 Author Report Share Posted May 25, 2011 umm did you buy that like that?? cuz you sir are making me jealous :lol: yes the motor was already setup up the way you see it in the pictures :D Quote Link to comment
Suspect Posted May 25, 2011 Report Share Posted May 25, 2011 Did the L18 come from the Factory with Dual Points Distributor? I believe the dual point distributor is from a 73 L16. It seems the only year and motor in the 12 trucks I've had that I've come across a dual points distributor... Quote Link to comment
datzenmike Posted May 25, 2011 Report Share Posted May 25, 2011 '73 610s had dual point L18s. The dizzy number is stamped on the side if you want to check. 22100 U2001 22100 U2002 22100 U2003 22100 U2004 Quote Link to comment
Mini-L320 Posted May 26, 2011 Author Report Share Posted May 26, 2011 '73 610s had dual point L18s. The dizzy number is stamped on the side if you want to check. 22100 U2001 22100 U2002 22100 U2003 22100 U2004 Thanks alot, I will deff check that out. Quote Link to comment
