hoopty Posted May 24, 2011 Report Share Posted May 24, 2011 My oil light came on 2 days ago and wont seem to turn off....:blink: I just put a weber on a week ago and was floored by the improved response of my l16, i actually got it to burn out :cool: Any ways, I did my oil about a month ago and cant seem think of why my dummy light came on, hopefully its nothing internal. I was just wondering if it is possible my sensor is bad/missleading, has this ever happened to anyone here, and come to find out their sensor took a shit? Quote Link to comment
Skib Posted May 24, 2011 Report Share Posted May 24, 2011 its on because your getting less than ~5lbs of pressure. check your oil... Quote Link to comment
hoopty Posted May 24, 2011 Author Report Share Posted May 24, 2011 i did its right at the high mark where it was a month ago when i filled it my pump or sensor could be taking a shit on me? I used quaker state oil, does any one know if L series engines hate this oil? Quote Link to comment
erichwaslike Posted May 24, 2011 Report Share Posted May 24, 2011 oil is oil for the most part. if ur lights on there is an issue. the sensor is seeing less tha 5lbs, cood be the sensor failing, cood be something blocking an oil passage way, cood be a failing oil pump, cood be the motor coming apart due to the recent flogging of said burnout and such. hook up a mechanical oil gauge to it to be sure u have oil pressure. if there isnt oil pressure dont rev it to see if it will get some, u will just do more damage. Quote Link to comment
Skib Posted May 24, 2011 Report Share Posted May 24, 2011 i did its right at the high mark where it was a month ago when i filled it ya that was a month ago, go check your oil to see what its at now. having less that ~5lbs of oil pressure is a bad thing :blink: Quote Link to comment
hoopty Posted May 24, 2011 Author Report Share Posted May 24, 2011 I did check it it is still right at the high mark where it was a month ago Quote Link to comment
Skib Posted May 24, 2011 Report Share Posted May 24, 2011 then you have a faulty sensor, faulty oil pump, or a blockage somewhere. a new oil pressure sender is only like $11 does it come on and then go off when you first turn the key to acc before you start it Quote Link to comment
ggzilla Posted May 24, 2011 Report Share Posted May 24, 2011 It should come on when you turn the key to ON/IGN. And go out when the engine is running. Hoopty, by 'dummy light', you mean the light labled "OIL", right? Or is the the CHG light? Quote Link to comment
datzenmike Posted May 24, 2011 Report Share Posted May 24, 2011 Pull the wire off the sender... It's mid way up the block between dip stick and oil filter. Yellow wire with red stripe. If it goes out, it's the sender or lack of pressure. If it stays on then the wire is touching ground somewhere between the sender and the dash light. Fix this or you will be hoopty 1 Quote Link to comment
hoopty Posted May 24, 2011 Author Report Share Posted May 24, 2011 I already am hoopty :P my oil light is the light i am talking about, i already tested if it was electrical and it goes off when disconnected and it does go on and off with ignition, it turns off for probably 15 seconds when started and comes back on. I am buying a new sensor off rock auto, i bought the 720 sender for an electrical gauge addition. now i just need a gauge i'm thinking its isn't the sensor though...:( Quote Link to comment
banzai510(hainz) Posted May 24, 2011 Report Share Posted May 24, 2011 those oil prssure swithc should be had locally in a parts store.PLUS they are the correct thread. NAPA should be able to get one sooner than Rockauto. also to let you now the thread hole is a 1/8 BSP size this mean you should get a adapter . cause most gauge jkits sold are 1/8 NPT. So dont be a real Hoptie and instal a 1/8 NPT in a 1/8 BSP. its close but dont put it in the block and it snapps off. If the 720 sender is from a nissan block already then yes it should fit fine. Quote Link to comment
datsunaholic Posted May 24, 2011 Report Share Posted May 24, 2011 If the light turns off, then back on that's usually a sign the oil is REALLY low. You say it's full, so there are a few possibilities: 1) You have the wrong dipstick and only have 1 quart of oil in it 2) The oil pickup tube is broke off in the pan, so it only picks up 1-2" of oil when full 3) The sender is bad 4) The oil is turning to foam (which could be caused by a bad mix of different oils or incompatible pour-in additives) 5) The oil pump's pressure relief valve is opening way too soon 6) The oil pump is totally worn out Me, I'd change the sender, but before I did that I'd put a mechanical gauge on it to verify there really is oil pressure. 1 Quote Link to comment
darrel Posted May 24, 2011 Report Share Posted May 24, 2011 open the oil camp while it's running. if you see the splashing around oil pressure is probably fine. Get a send unit if the oil coverage looks good. sending units are prone to failure, pumps not so much in regular driving.(not continuous racing) Quote Link to comment
izzo Posted May 24, 2011 Report Share Posted May 24, 2011 Mine kept coming on, was a faulty sensor. Replace it and it was fine (it leaked too tho) Quote Link to comment
hoopty Posted May 24, 2011 Author Report Share Posted May 24, 2011 Thanks a bunch guys! I'll update once I get out of bed, I just had food poisoning onset..... :(( Not such a good week... Quote Link to comment
hoopty Posted May 29, 2011 Author Report Share Posted May 29, 2011 Huge sigh of relief, it was the sensor:rolleyes: Quote Link to comment
ddrum Posted September 9, 2011 Report Share Posted September 9, 2011 My oil light came on 2 days ago and wont seem to turn off....:blink: I just put a weber on a week ago and was floored by the improved response of my l16, i actually got it to burn out :cool: Any ways, I did my oil about a month ago and cant seem think of why my dummy light came on, hopefully its nothing internal. I was just wondering if it is possible my sensor is bad/missleading, has this ever happened to anyone here, and come to find out their sensor took a shit? I have a freshly rebuilt L16 with a 5 speed and i cant get it to burn out. Mine just bogs down when try to burn out and it bounces like crazy. Quote Link to comment
