Bunchy Posted May 4, 2011 Author Report Share Posted May 4, 2011 how easy would it be to swap one of them badboys? Quote Link to comment
jalen Posted May 4, 2011 Report Share Posted May 4, 2011 Pretty easy. I like that color. Now you need to slam it and put some chrome fender mirrors on it. Quote Link to comment
Laecaon Posted May 4, 2011 Report Share Posted May 4, 2011 Pretty easy. I like that color. Now you need to slam it. Fixed! Fender mirrors just ruin good fenders. Quote Link to comment
philcas1987 Posted May 5, 2011 Report Share Posted May 5, 2011 Fixed! Fender mirrors just ruin good fenders. Too much fender mirror hate around here. This car though would look funky with them. Quote Link to comment
Bunchy Posted May 7, 2011 Author Report Share Posted May 7, 2011 my tranny is starting to slip Quote Link to comment
hobbes_the_cat Posted May 7, 2011 Report Share Posted May 7, 2011 Your clutch is slipping? easy fix, new clutch.;) Quote Link to comment
Bunchy Posted May 7, 2011 Author Report Share Posted May 7, 2011 yeah it slips when i go into 2nd and 3rd and vibrates hard for a little while....:unsure: Quote Link to comment
hobbes_the_cat Posted May 7, 2011 Report Share Posted May 7, 2011 look in the drivetrain section. the best and cheapest clutch part numbers are listed in there. should be able to get all you need for around $150 new. Quote Link to comment
banzai510(hainz) Posted May 7, 2011 Report Share Posted May 7, 2011 sell this wagon to me!!!!!!!! importrp.com sells stock daiken clutches. and has T/O bearings also. also they sell SPEC brand clutches also. hard to surf the site but they do offer lots of clutches. Make sure you know what motor you have in there just in case you have a L20 or soemthing. then it could be different if a truck L20 was installed(trucks had 225mm flywheels) If flywheel as any grooves in it you need to pull it and get it surfaced. I didnt do it and always wondered why my clutch would slip about every 1.5 years with Roadster Pressureplate. Then I got a good flywheel and it never went bad since. Duh!!!!!! roadster pressure plates are great also if you can find them. Quote Link to comment
Bunchy Posted May 7, 2011 Author Report Share Posted May 7, 2011 :blink: IM NOT SELLING MY WAGON! I have the l20b in my goon with a 4 speed tranny.. Quote Link to comment
banzai510(hainz) Posted May 7, 2011 Report Share Posted May 7, 2011 Hope its a 200mm clutch in there but then again it could be a 225mm in there unless you know the history. all L20 cars had 200mm flywheels all L20trucks had 225mm flywheels But I will lean on the side of the 200mm. Quote Link to comment
Bunchy Posted May 8, 2011 Author Report Share Posted May 8, 2011 :rolleyes: the l20b i have is out of a 200sx Quote Link to comment
Bunchy Posted May 9, 2011 Author Report Share Posted May 9, 2011 Random oics!:D Quote Link to comment
banzai510(hainz) Posted May 9, 2011 Report Share Posted May 9, 2011 you aint got that engine bay cleaned up yet? Get that TR3 cleaner and hand goop and clean up the rubber and engine bay. It works good. I like this wagon!!!!!! Quote Link to comment
DatDoug Posted May 9, 2011 Report Share Posted May 9, 2011 Very cool car :cool: Sweet roof rack :thumbup: You already got the weber. Find a front bumper, dogleg 5 speed, elec. ign., & new rims & tires & roll! If you dont like the roof raCK sell to me :poke: Quote Link to comment
Bunchy Posted May 9, 2011 Author Report Share Posted May 9, 2011 Thanks..It already has a electronic iginition and im going to get some tr3 cleaner soon then I will post some oics up of the result. I will sell the roof rack but how am i going to not have leaks in my roof..? Quote Link to comment
MicroMachinery Posted May 9, 2011 Report Share Posted May 9, 2011 I wouldn't disturb the rack. Just leave it.. some day you may change your mind about it, and then you'll have to go buy another one and install it. To keep the roof from leaking, you'd have to fill in the holes by either welding them or filling them in with something else.. like I said, just leave it for now. I think the factory racks were a cool option to end up with. Quote Link to comment
hobbes_the_cat Posted May 9, 2011 Report Share Posted May 9, 2011 Yeah, don't ditch the roof rack! You'll regret it. (sorry Doug:D) Quote Link to comment
banzai510(hainz) Posted May 9, 2011 Report Share Posted May 9, 2011 agree, leave the rack!!!!! Quote Link to comment
Bunchy Posted May 9, 2011 Author Report Share Posted May 9, 2011 i geuss i will leave the rack:rolleyes: ... Quote Link to comment
banzai510(hainz) Posted May 10, 2011 Report Share Posted May 10, 2011 i bought a clutch thru http://www.importrp.com/ I bought a stock Daiken my 521 a few years ago,like 87$ just got a SPEC brand stage 1 in the mail last nite.to replace the one on 521 as the rear main sela is bad cuasing clutch to go bad. Maybe a Spec would be a good choice for you also but its about 210$. It dont have a place of orgin. Like USA Japan or Korea or what ever. SpEC says in house so I worte and say why dont you put Made in USA stickers all over it. Waiting for a response. In yoursitiatation I dont know which pressure plate you have since the motor came out of a 200sx. cause the 200sx does have a diffent diaphrame height than a 510. so there might be a different T/O bearing sleeve length. what I did with mine is lay them on the floor and measure with tape measure th where the finger springs are at from the floor. if same then use the same T/O bearing sleeve. Quote Link to comment
MicroMachinery Posted May 14, 2011 Report Share Posted May 14, 2011 Hey, I was in McMinnville last night and I saw a guy in wagon that looked alot like yours. Was that you? I honked. Quote Link to comment
Bunchy Posted May 14, 2011 Author Report Share Posted May 14, 2011 hahah yeah that was me bro you were in some gray car and i waved back i tryed to follow you because i saw you over by el primo Quote Link to comment
MicroMachinery Posted May 15, 2011 Report Share Posted May 15, 2011 Yeah, I was in my 610. I was delivering pizzas :cool: You down this way often? Quote Link to comment
Bunchy Posted May 16, 2011 Author Report Share Posted May 16, 2011 my mom lives in mac Quote Link to comment
