NWOleman Posted February 22, 2008 Report Share Posted February 22, 2008 How do i lower the front of my 610 wagon about 2 inches? Do i have to get new struts or what? If i have to get different struts from a different car what do i get them from? O by the way its a 1973 610 wagon. Thanks NWO Quote Link to comment
74datto Posted February 29, 2008 Report Share Posted February 29, 2008 if you get some info on lowering your 610 let me know i need to do the same Quote Link to comment
NWOleman Posted March 1, 2008 Author Report Share Posted March 1, 2008 Will do. I hadnt heard anything. Sweet another 610 guy! Quote Link to comment
kiznook Posted March 1, 2008 Report Share Posted March 1, 2008 sweet another 610 lowering thread :D Quote Link to comment
Icehouse Posted March 2, 2008 Report Share Posted March 2, 2008 The 610 is the same as a 510 suspension wise. Get some zx struts and a set of Ground Control coilovers, get that sucker LOW! :D like this.... (I wish I had a 610, find me one :D ) Basically shortened struts with GC "coilovers" I used VW inserts which I don't really like but haven't changed them yet. Quote Link to comment
bonvo Posted March 6, 2008 Report Share Posted March 6, 2008 or if your low on funds like i am you could just hack a coil off the stock springs yes i know this isnt the best for performance and it would only be temperary till i can get the coil overs but it would work Quote Link to comment
banzai510(hainz) Posted March 6, 2008 Report Share Posted March 6, 2008 shorten the lower part of the strut and keep the spring the same or maybe wack one coil so you have a smoothe ride w/o loosing your suspension travel and breaking alternator bolts(if L16) Quote Link to comment
NWOleman Posted May 17, 2008 Author Report Share Posted May 17, 2008 How do you shorten the bottom part of a strut? I want to do this cheap! Ratsun style! Quote Link to comment
]2eDeYe Posted May 17, 2008 Report Share Posted May 17, 2008 Grind the lower spring mount off of the strut body slide it down 2" and weld it back on. Take your time with the welding as to not burn thru the strut body. Tack every inch or so around the body allow it to cool. Run another set of tacks let cool and so on til there is a continuous weld holding the mount on. Not adjustable, bu you'll drop 2"s ;) Quote Link to comment
Burabuda Posted May 19, 2008 Report Share Posted May 19, 2008 the rage on 510's is to use mr2 inserts, they're shorter, and help keep suspension travel unfortunately, they're only available in illumina-5's which are stiff and expensive Quote Link to comment
sr71sss Posted May 22, 2008 Report Share Posted May 22, 2008 the rage on 510's is to use mr2 inserts, they're shorter, and help keep suspension travel unfortunately, they're only available in illumina-5's which are stiff and expensive He said stiff and expensive in the same sentence:D heheh Quote Link to comment
Burabuda Posted May 22, 2008 Report Share Posted May 22, 2008 He said stiff and expensive in the same sentence:D heheh never mind the clever jokes, what were you thinking putting your 1800sss coupe on c.l. :glare: Quote Link to comment
