Suspect Posted April 18, 2011 Report Share Posted April 18, 2011 I put the gas tank from my 74 620 into my 73 620. I put 1.5 gal in it, ran it to the gas station, put another 2.5 gal in it and drove it to autozone and back which was maybe a couple miles one way. On my way back it started to run out of gas. I couldn't believe it could go threw that much gas. I pulled the plug on the drain on the gas tank and let out at least 2 gallons and it was still coming out. I poured the gas back in it, then tried to run it again. It wasn't barely pumping any gas. I checked the carburetor inlet and it was clean and everything was nice and free. I swapped another fuel pump on it still the same thing. I decided to pour more gas in the tank and now its fine. Why wouldn't the truck be able to pick up from at least 2.5 gallons left in the tank? Quote Link to comment
pharouh Posted April 18, 2011 Report Share Posted April 18, 2011 Piece of dirt in the filter or fuel line? Quote Link to comment
datsunaholic Posted April 18, 2011 Report Share Posted April 18, 2011 Tank pickup could be broken off or have a hole rusted in it a couple inches up. Or it's bent. Quote Link to comment
datsunrides Posted April 19, 2011 Report Share Posted April 19, 2011 Tank pickup could be broken off or have a hole rusted in it a couple inches up. Or it's bent. That would have been my guess. Mark Quote Link to comment
datzenmike Posted April 19, 2011 Report Share Posted April 19, 2011 If you remove the sender you can at least look in and see the pick up tube. Quote Link to comment
Suspect Posted April 19, 2011 Author Report Share Posted April 19, 2011 I was thinking it was something to do with the pickup in the tank. When it wouldn't get gas, I took the fuel line off the fuel pump, took the gas cap off, and with a compressor blew air threw the line and at the gas tank end, all I heard was air. Quote Link to comment
herculesinwyoming Posted April 20, 2011 Report Share Posted April 20, 2011 im working on the same issue, but mine is totally plugged up, air compressor even at 80 psi couldnt get through, i will have to track down the blockage, i know from the fuel filter to the junction block on the frame is clear so i will have to test the rest of the line when it isnt snowing. Quote Link to comment
