sdsurf Posted February 13, 2008 Report Share Posted February 13, 2008 create a L series 5spd sticky... 521. I can't be more confused Quote Link to comment
]2eDeYe Posted February 13, 2008 Report Share Posted February 13, 2008 Which part is confusing? Pac already told you the best swap to do.... Id go w/ the 81 Z trans. All you'd have to do is shorten the trans mount a bit & swap the mounts. I can help weld the mount if need be,should be the same size as mine [82 ZX trans.] Remember use the truck throw out bearing & clutch slave. When your ready bring it down & we can have it done in 1 day :D All that's left is to get the tranny and swap it in... :) Quote Link to comment
