blackdeth666 Posted March 16, 2011 Report Share Posted March 16, 2011 So I got new doors for my 521 that are in way better shape than my existing doors, but the windows and wing window frames are pretty ugly. So I want to switch them out with my old windows. Ive undone all the fasteners but I can't quite figure out how to get the assembly out. Does anyone have any tips for me? Quote Link to comment
'70 521 L16 Posted March 16, 2011 Report Share Posted March 16, 2011 i just recently installed new glass, mine was broken though so i didnt have to remove anything. if it helps at all i had to put the window in from the top rotated 90 degrees clockwise. once it was in the door i rotated back upright and popped the arm assembly into the groove on the window. MAKE SURE you remove the drop stop thing that keeps the window from going down all the way. it sticks out about an inch into the tiny space youre working with. not much but its enough to break the glass if you hit it right. good luck. sorry dont know anything about the vent windows :-/ Quote Link to comment
DanielC Posted March 16, 2011 Report Share Posted March 16, 2011 Door dissassembly: Remove the window handle, and the door handle. Phillips screws in the center. Remove the upholstery cover. Gently pry around the clips near the edges of the panel Remove the plastic covering the holes in the door. just glued on. Remove three screws around door catch on rear edge of door. Remove two screws holding door release handle mount (above window regulator) Remove two screws holding bell crank near bottom back edge of door. Remove door lock plunger knob. Remove clip holding lock linkage onto door lock cylinder. Remove door lock linkage mechanism out through inspection hole in door. Remove the window down stop. Two Phillips screws. Remove the roller on the window regulator from the channel on the bottom of the glass. You may have to remove the four screws that hold the regulator to the door. Leave the window regulator and glass in the bottom of the door. The service manual recommends putting a piece of string around the bottom of the window to pull it up later. Remove the four small screws on the top of the door frame front edge. Carefully pry the weather strip up out of the window opening inside and outside edges Remove two bolts that hold front window guide. One is in a hole in upper part of inner door panel. Pull wing window, and front window guide assembly to the rear at the top, and slide it out of door. Pull window regulator out of inspection hole in inner door. Pull glass out of door. Quote Link to comment
blackdeth666 Posted March 17, 2011 Author Report Share Posted March 17, 2011 Thanks daniel, got out out! Quote Link to comment
