siege Posted March 4, 2011 Report Share Posted March 4, 2011 Hey guys I am new here and just picked up a 78 620 KC I am thinking of doing a vg swap in. I have done a search on this but can't find what I am looking for on this topic I already have the 5 speed tranny from a 90 hard body with cross member and can get the vg for next to nothing. So what am I looking at as far as motor mounts wiring and tranny mounts is this a bolt in thing or is there a ton of fab work to do. Also forgot I am going to run a carb on this. 1 Quote Link to comment
dash Posted March 4, 2011 Report Share Posted March 4, 2011 Im telling you right nowyour gitting your self in to a lot of work... I started my vg sawp like a mont ago and have barley started and theres lots of fab work to be done to fit that motor in a 620... Are you going with the vg30de or the edtt? Do you have A shop do you know whay type of supenchen your going to have? 1 Quote Link to comment
siege Posted March 4, 2011 Author Report Share Posted March 4, 2011 Ya I have a shop and was going with pretty much stock suspension this is some thing that I am not dead set on because I really do not want that type of project I just want to be able to drive it and enjoy it you now. 1 Quote Link to comment
dash Posted March 4, 2011 Report Share Posted March 4, 2011 well the the torsion bar gits in the way.... so you might want to consiter an alternative swap.... because this is will take some time to do proprly 1 Quote Link to comment
motavated Posted March 4, 2011 Report Share Posted March 4, 2011 You just read this thread.... http://community.ratsun.net/topic/15744-620-vg-conversion/page__p__212685__fromsearch__1#entry212685 Quote Link to comment
yello620 Posted March 4, 2011 Report Share Posted March 4, 2011 The torsion bars can be worked around, but let me tell you this takes time and a lot of fabrication. The wiring is not a problem. Its the custom oil pan, motor mounts, driveline, cooling system, Alternator mount. And then hood clearance depending on which intake you use. I would not even think of running a carb. Half the reason for the conversion is the injection. You have already gotten the link to read, thanks Motavated. The link is also in my signature. Quote Link to comment
dash Posted March 4, 2011 Report Share Posted March 4, 2011 yello620 what year vg did you use in your conversion Quote Link to comment
yello620 Posted March 4, 2011 Report Share Posted March 4, 2011 I have such a mixed mess right now. The motor is a 90 or 91 from an Infiniti M30, the trans is from an 85 Z31, the intake and exhaust manifolds are from a 87/88 S12. Alternator and starter come from a 96-99? Pathfinder. That was the magic starter to clear the torsion bar. So far, it looks like the best donor car for this would be the 87/88 S12. Same as the donor car for the 510. Quote Link to comment
dash Posted March 4, 2011 Report Share Posted March 4, 2011 I have such a mixed mess right now. The motor is a 90 or 91 from an Infiniti M30, the trans is from an 85 Z31, the intake and exhaust manifolds are from a 87/88 S12. Alternator and starter come from a 96-99? Pathfinder. That was the magic starter to clear the torsion bar. So far, it looks like the best donor car for this would be the 87/88 S12. Same as the donor car for the 510. the vg i have is a '93- '96 i think and im lookin for a '86-'89 z32 FS5R30A and some other bits and ends Quote Link to comment
yello620 Posted March 4, 2011 Report Share Posted March 4, 2011 the vg i have is a '93- '96 i think and im lookin for a '86-'89 z32 FS5R30A and some other bits and ends 93-96 vg what?? e, or de? The starter design on the Z32 transmission WILL NOT work with torsion bars. Quote Link to comment
dash Posted March 4, 2011 Report Share Posted March 4, 2011 Dett. And I know... I all reddy got it out of the picture. And gitting reddy to put on air bags =-) Quote Link to comment
datzenmike Posted March 4, 2011 Report Share Posted March 4, 2011 Also forgot I am going to run a carb on this. Without EFI how will you work the distributor?????? Quote Link to comment
siege Posted March 6, 2011 Author Report Share Posted March 6, 2011 Without EFI how will you work the distributor?????? Sorry guys I meant the vg30e for some reason I was thinking de when I posted. As for the dizzy I was thinking of running it the same way they are doing it with the 510. Quote Link to comment
dash Posted March 7, 2011 Report Share Posted March 7, 2011 o on its no problem ... well if you need any help just pm me and ill try to help the best i can Quote Link to comment
Bullet_theory Posted March 8, 2011 Report Share Posted March 8, 2011 Im telling you right nowyour gitting your self in to a lot of work... I started my vg sawp like a mont ago and have barley started and theres lots of fab work to be done to fit that motor in a 620... Are you going with the vg30de or the edtt? Do you have A shop do you know whay type of supenchen your going to have? wow.... im having problems making it past that one word, i didnt get what it was untill i read the post after Sorry guys I meant the vg30e for some reason I was thinking de when I posted. As for the dizzy I was thinking of running it the same way they are doing it with the 510. and what way would that be, magic? unicorns? .....having an ethiopian child wired to the coil? Quote Link to comment
siege Posted March 19, 2011 Author Report Share Posted March 19, 2011 wow.... im having problems making it past that one word, i didnt get what it was untill i read the post after and what way would that be, magic? unicorns? .....having an ethiopian child wired to the coil? WOW your nice guy!!!! Well I would run the dizzy the same way this guy did. Quote Link to comment
yello620 Posted March 19, 2011 Report Share Posted March 19, 2011 Do you have more pics of that install? And how about some info on how they are controling the distributor, what computer are they using? Quote Link to comment
siege Posted March 20, 2011 Author Report Share Posted March 20, 2011 Do you have more pics of that install? And how about some info on how they are controling the distributor, what computer are they using? Sorry that is the only pic that I have on this swap there is a guy on here that has this exact swap in his 510 the car is black and he is running the carb setup to. If I can find it again I will post the link to his car and build but for now here is a short vid of a yellow 510 running the carb my buddy has a web site that has all the stuff to make the swap work right I can try and get up for to. Oh ya I don't see any magic unicorns or an ethiopian child wired to the coil? in there Quote Link to comment
odmanjohnson Posted March 22, 2011 Report Share Posted March 22, 2011 think the 3 liter is hard im still workin on on my 5.0.... 3+ yrs, of course not every day... Quote Link to comment
Llittle_Llama Posted March 27, 2011 Report Share Posted March 27, 2011 I'm running Ziggy Stardust on my dizzy, I don't have a swap though so it might not help your build :( Quote Link to comment
Bullet_theory Posted March 27, 2011 Report Share Posted March 27, 2011 that one is better, the other one he said he had 2 plugs swapped... wich is why it sounded overly lopey..... hmmm now im kinnda curious about this swap Quote Link to comment
