Muffler recomendations
d510addict
I am going to put 2 inch exhaust on my 1970 521 and am looking for a muffler that will offer a good balance between performance and sound. I have poor hearing as is and would like something that isn't super loud, I would also like it to fit in the stock location. Any recommendations?
And where is a good spot to run the tail pipe out from underneath the bed? Mine doesn't have much of a tail pipe atm so i do not know where to run it.
  • Replies 19
I use a CherryBomb turbo muffler. Not top of the line, but it's a nice inexpensive, readily available muffler. It's not too loud, not too quiet and certainly not restrictive. I would recommend it if you're looking for a cheap solution cool.gif Good news is, if you don't like it it's only $22 bucks down the drain laugh.gif
http://www.jegs.com/i/Cherry-Bomb/545/87701/10002/-1?parentProductId=769809
also fits 510 wagon and rear 510 sedan PERFECTLY which wants a small case muffler.
Thrush makes one also in close to same size and fit the stock location.
This is the smallest case size they make I believe
I have a Dynomax Super Turbo which is good quality but gets on the louder side when cruiseing about 65mph.
I will use my Cheerybomb2 as listed above series next if my Dynomax muffler ever wears out.
my 521 it exists out the right rear tire slightly down
http://www.jegs.com/...roductId=769809
Mr. banzai show some oic's to see it, i'll show you guy's my 2 1/2 inche pipe from the front to the back with a manoflow mofler. show pic's,pic's pic's man. :thumbup:
For some reason I cant post anymore on this site,need to update the browser.
well anyway my exhaust looks like stock just a 1.75 in pipe&muffler with Super Turbo in stock location on my 521
I will go to 2in if it ever wears out.
2.5 inc is too much. I bet you get better power with a smaller 2in pipe unless you got a turbo motor
I don't know if you called a L20 with 2 sidedrafts with an A87 head with headers, turbo motor but sure run's and sounds great. :devil:
