Coolant inlet for Saturn Alt. Swap
  • Replies 5
The 620, it has an idler arm and grease fitting that the alternator gets very close to when you swing it away from the block to tighten the belt. Well if you run a larger than stock diameter alternator. I fit a 720 50/60 amp on my 620 and used a shorter belt. Had to slip the belt onto the pulley first and then put the two lower mounting bolts in and tighten them. The 280z/zx rad inlet positions the hose up and to the rear slightly to give a bit more room close to the block for the larger alternator. I don't know if the Saturn alt is larger or not... there may be no fitment problems.
