cleaning out the 510 parts
1) long rod 2089 L-series race engine complete. 2.2 block 2.0 liter crank, 152.45mm lz20 rods. Isky cam and springs, unilite dist,set up for holly 500,(no carb) datsun comp header, datsun comp aluminum flywheel. this is a used race eng.so the clutch needs serviced, the valve springs should be replaced. runs good $500 offer,
2) 510 adjustable rear beam. This is a new beam I built w/1/4 steel brackets. slotted both inside and outside. sealed mono balls in the A arms. 9/16 bolts through the brackets and arms. Its real stout! adjustable for camber and toe The real deal.
It should be worth $500. But make me an offer.
3) misc 510 nuts bolts etc. I,ve got a bunch of pieces from parting out 510,s and some eng. bearings. I just found a 3.90 diff.
Call me about any of this stuff.
The eng and beam are in north seattle
Rick Davidson 509 989 2028 ricncath@dishmail.net
  • Replies 1
