monk Posted February 18, 2011 Report Share Posted February 18, 2011 Hey! Has any one run thier cam timming a tooth advanced? I know Pintos and such respond well to this little trick I was wondering if Datsuns do as well? Thanks Monk Quote Link to comment
Skib Posted February 18, 2011 Report Share Posted February 18, 2011 well theres 3 timing settings on the cam gear. which one do you have it on? Quote Link to comment
datzenmike Posted February 18, 2011 Report Share Posted February 18, 2011 The Ford motor may have been adjusted that way for emissions (the 460s were) and will benefit from some advance. You're assuming that Nissan did the same which I think they did not. (at least not to the extent Ford did) Very generally advancing a cam brings the power on sooner and retarding a cam brings it on later. This is most noticable on a large overlap cam than a stocker. The only way to tell is run the L series in the #2 hole (stock) location on a dyno and get a base reading and then try the #1 hole which will retard about 4 degrees and get a reading. Now put on #3 for a 4 degree advance and get a reading. You now have -4, 0 and +4 readings. If you wish to try even more advance and retard simply go back to the #2 hole and move one tooth forward or back. this will give you 9 degrees of each. You can even split the differens slightly by advancing 4 degrees to the #3 hole and retarding one tooth 9 degrees for +4 plus -9 = -6. You now have -9 -6 -4 0 +4 +6 +9 to work with. Simple Quote Link to comment
