izzo Posted February 17, 2011 Report Share Posted February 17, 2011 71 521 Body is in excellent shape, one or two small dings (you gotta feel for em). No cancer, some surface rust in spots but nothing serious and easily fixed. Motor work done; Motor has been rebuilt, cylinders honed, new bearings, rear main seal, rings etc, new water pump Original head has been replaced with an A87, i believe its a peanut head (its remanned as well) Transmission was taken out and seals/bearings were replaced, clutch has been replaced Carrier bearing was replaced within ~20k miles (it was a few years ago, but low miles since) Brakes were gone thru, new shoes, new seals, new bearings. They were adjusted about 4 months ago, about 1500 miles since. New tires, and rims from les schwab. New shocks up front, as well as the rear. Add a leaf in the rear. NOS tail lights and buckets installed, new driver side window regulator. New battery New voltage regulator Alt has been rebuilt Weber carb with manual choke (works great too!) New clutch slave/master & hard line, i think the soft line was replaced too Regular oil changes, maintenance has been kept up. New 1 3/4 Exhaust into a turbo muffler. Crack free Dash Seat has some rips in drivers side, seat cover is junk too and needs replaced. I know there is more that i am missing but you get the idea Some of this work is recent, some is older, but all within ~20K miles There's thousands of dollars in receipts on this truck and you will get them all. ~$9000+ The left turn signal does not work. Hazard lights did for a while but don't anymore, I am sure its just the flasher relay needing replaced. I cleaned the gas tank out, but the filler neck needs replaced. its cracked pretty bad and stuff is getting in there. I just cleaned the carb out today and put a new paper filter on it (see thru), and cleaned the glass filter out. Took it for a run around town and its been great. I would suggest dropping the tank one more time, cleaning it, and replacing the filler hose to eliminate the issue. $1500 Firm. I am throwing in a good dogleg with this. I was told it whines in third, since its already out you can replace the bearing easily before putting it in the 521... Please no "GLWS" or comments. Any questions, PM me. 1 Link to comment
datzenmike Posted February 17, 2011 Report Share Posted February 17, 2011 Please no "GLWS" or comments. Buyers 1/ Replies WILL be limited to questions about the item for sale and 'reasonable offers'. All others will be removed at the moderators discretion. Don't worry about useless comments. They will be deleted and the biggest offenders will get a warning. Link to comment
Ken_B Posted February 17, 2011 Report Share Posted February 17, 2011 Think shes a good d/d candidate? Got the door panels or they gone? Tailgate? Oh the things I would do for that dash :blink: Link to comment
izzo Posted February 17, 2011 Author Report Share Posted February 17, 2011 Think shes a good d/d candidate? Got the door panels or they gone? Tailgate? Oh the things I would do for that dash :blink: Yeah, ive been driving it every day, and taken it on a few trips 300+ miles. Just need the fuel tank cleaned out and a new filler neck. No door panels sorry, no tail gate either just that net. Have clean/clear title. Good tabs Link to comment
izzo Posted February 28, 2011 Author Report Share Posted February 28, 2011 Bump Interested in trades too -- 720 or hardbody king cab 4x4 pathfinder (only really interested in the early editions with the naps 2.4 but consider one with a vg30) Link to comment
thisismatt Posted February 28, 2011 Report Share Posted February 28, 2011 sold to yours truly :P 1 Link to comment
