clean71 Posted February 16, 2011 Report Share Posted February 16, 2011 up forsale is some datsun 510 Nos brand new parts ive been sitting on for some years now....all parts are for L16-L18 1.spark plug wires OEM $25 2.Water pump Oem $65 3.Clutch Oem $100 4.Clutch disc Oem $35 5.Fan blade Oem $40 6.Air filter Oem $25 Link to comment
mike Posted February 18, 2011 Report Share Posted February 18, 2011 That fan looks like its for a later L with a clutch fan. Is the water pump the early (non clutch) style or the later clutch style one that fits the fan? Being OEM Id guess that its a cast impellar too. ...The 7 blade fan will make contact with the original fan shroud in an early L16/L18 620 but if you run a later shroud with the later 3 core rad it cools much better than the stocker. Link to comment
clean71 Posted February 19, 2011 Author Report Share Posted February 19, 2011 That fan looks like its for a later L with a clutch fan. Is the water pump the early (non clutch) style or the later clutch style one that fits the fan? Being OEM Id guess that its a cast impellar too. ...The 7 blade fan will make contact with the original fan shroud in an early L16/L18 620 but if you run a later shroud with the later 3 core rad it cools much better than the stocker. Yes the fan blade is for a later 510 but the water pump is for a early 510.... Link to comment
Exlaxracing Posted April 30, 2012 Report Share Posted April 30, 2012 What is the diameter of the fan I need one for my l16 Link to comment
NSRz32 Posted April 30, 2012 Report Share Posted April 30, 2012 Have a pic of the plug wire set? Link to comment
banzai510(hainz) Posted April 30, 2012 Report Share Posted April 30, 2012 NSR you can get the NGK wire sets NE64 on line . rockauto.com maybe water pump I think Carquest carries the Atsugi marked ones(OEM) If you can get hese for a good deal get them. Link to comment
