Zeusimo Posted February 15, 2011 Report Share Posted February 15, 2011 So, You've Decided To Change Your Valve Stem Seals? Great, This Is Just A Little Guide To Help You Out On You're Grand Adventure.. First Off Gather Your Required Tools And Parts - Overhead Valve Spring Compressor http://www.summitrac...parts/OTC-4573/ - New Valve Stem Seals I Read Somewhere On Here That You Can Also Use Ford Valve Stem Seals Made Of Viton Better Material And Desired For Performance Cam Applications Upto 0.600"+ Unfortunately I Can't Find The Thread Anymore (Maybe Datzenmike Will Shine On This?) So I Used Regular Fel-Pro SS 27149 - 8 Sammich Bags To Hold Rockers, Springs, Etc... IN ORDER!!! - 7.5" PVC Pipe Or Wooden Block - Basic Tools, Sockets, New Valve Cover Gasket Would Be Nice 1 Quote Link to comment
Zeusimo Posted February 15, 2011 Author Report Share Posted February 15, 2011 Ok, Now For Preparation - Remove Hood And Set Aside (Unless You're A Midget And Won't Bump Your Head Every 2 Seconds) - Disconnect Battery (Not Really Necessary Just Common Practice) - Remove Spark Plugs - Remove Valve Cover Quote Link to comment
Zeusimo Posted February 15, 2011 Author Report Share Posted February 15, 2011 I Guess Now You're Ready To Begin Set Motor At Top Dead Center Should Look Like This Either Position 1, 2, Etc.. Loosen Cam Sprocket And Set To TDC Once More Make Sure The Left Side Of Chain Is NOT Loose Now With Wooden Block Or Like Me And My PVC Pipe Jam The Chain So It Won't Work Itself Loose Now You Can Remove Sprocket And Drop Chain Next Step Is To Remove Rockers List Spring From Original Position And Unhook Remove All Of These And Place In Appropriate Sammich Bag Quote Link to comment
Zeusimo Posted February 15, 2011 Author Report Share Posted February 15, 2011 Now Loosen The Rocker Lock Nut Now Loosen And Backseat Rocker Adjusting Nut Clockwise REMEMBER: Lefty Loosy, Righty Tighty Now To Remove Rockers I've Uploaded A Quick Little Video To Help You Out http://www.youtube.com/watch?v=_xDTdLGwHBQ Now That You've Removed The Rockers It's Time To Slide The Cam Out Quote Link to comment
Zeusimo Posted February 15, 2011 Author Report Share Posted February 15, 2011 First Remove Retainer Plate Loosen Left Motor Mount And Lift Motor Until You Have Enough Clearance To Slide Cam Out Now That You've Removed The Cam Stuff Each Cylinder With Rope To Hold Valve In Place Place Valve Spring Compressor On Springs, Compress And Remove http://www.youtube.com/watch?v=H4jwa8aBYPc Simply Remove Old Seals With Pliers And Replace With New Ones First Place Condom On Valve, Carefully Slide Oiled Seal Through Stem And With Socket Push Down Until It Pops Into Place http://www.youtube.com/watch?v=xG6HLVFEPT0 Repeat Process On All Cylinders Now Repeat Entire Process Backward For Assembly, Adjust Valve Lash And You're Ready To Go :lol: 1 Quote Link to comment
datzenmike Posted February 15, 2011 Report Share Posted February 15, 2011 If you are at TDC the #2 and #3 pistons are at the bottom of their stroke. It'll take a lot of rope to fill the cylinder and hold the valves in place. Quote Link to comment
Shagy Posted February 15, 2011 Report Share Posted February 15, 2011 another trick is to use a leak down tester and apply air to the cylinder to valves seated... Quote Link to comment
deadmonkey Posted February 15, 2011 Report Share Posted February 15, 2011 I did something similar accept did two cylinders at time. Leave cam sprocket on at first ( but can break the bold loose) Opened two cylinders up, stuffed each end of rope into both cylinders and manually moved cylinders up tight against the rope, securing the valves in very well. I then marked the CENTER of the chain link and on the sprocket with something that won't wipe off easily (a silver sharpy works fine). Then remove the rockers if haven't done already then remove the camp plate and pull out the front making sure not to bind or scratch the surfaces. It is kind of a pain, but that way I am CERTAIN I won't drop a valve into the cylinder. I stuffed about 5' into each side and made sure to use nice soft nylon rope to nothing got bent or scratched. Just put the cam sprocket back on (matching up the marks), lossen the cylinder, take out the ropes and do the same thing for the other two. It took me like 2 hours I think, but only because I had never done it before. Quote Link to comment
datzenmike Posted February 15, 2011 Report Share Posted February 15, 2011 I guess you can't get at the valve spring with the cam in? Pretty sure I saw a pry bar type compressor you slip under the cam for leverage. Very fast and the cam stays in. Quote Link to comment
mklotz70 Posted March 10, 2011 Report Share Posted March 10, 2011 Zeusimo.....great thread!! Great work!! Thanks!!! I've seen the pry bar style.....I'm curious how well it works. I'd probably throw the cam in and rotate everything 180 to get the other two pistons to the top, but not having to remove the cam would be sweet. :) Be careful with the air setup.....if the piston is down and the valve seal is not good to the head(either from carbon build up or because you bump the vavle) ....you can drop a valve. 1 Quote Link to comment
Shagy Posted March 10, 2011 Report Share Posted March 10, 2011 well thats what the air pressure is for though....to keep the valve up. Quote Link to comment
mklotz70 Posted March 11, 2011 Report Share Posted March 11, 2011 Yep...you're right....I was just saying to be careful if they go that route. Once you get the pressure up over about 40 psi, it will push the piston down if you don't have it at exactly TDC....which leaves plenty of room for the valve to fall. Not rotating the engine because of the timing chain is one of the challenges. Pluse, it all hinges on the valve having a good seal. Carbon deposits can cause a leak and accidentally hitting the end of the valve stem can break the seal. .....BUT....I have used that method and it worked well. I actually used the hose from a compression tester with a quick connect to the gauge. Quote Link to comment
datzenmike Posted March 11, 2011 Report Share Posted March 11, 2011 Air will work but it requires hoses, fittings and a compressor, or need to be near one and electricity. The risk is loss of pressure from a leak or electricity. Rope can be used anywhere even out in the desert..... and you can stop for the night and finish in the morning without worry and an absolute guarantee that the valve cannot possibly fall in. Occam's Razor, (also known as The Principle of Plurality - Plurality should not be posited without necessity The Principle of Parsimony - It is pointless to do with more what is done with less .... The simplest solution is most often the correct one. Quote Link to comment
mklotz70 Posted March 11, 2011 Report Share Posted March 11, 2011 Just got a JEGS catalog yesterday. Here's their info for the air adapter to hold the valves up. AIR HOLD ADAPTER 555-80522 $9.99 FLEXIBLE AIR VAVLE HOLDER 555-W84003 $9.99 Quote Link to comment
pl521sss Posted March 13, 2011 Report Share Posted March 13, 2011 Thanks for taking the time for the write up Quote Link to comment
Zeusimo Posted March 13, 2011 Author Report Share Posted March 13, 2011 Thanks For The Positive Feedback :D Found Out Where I Read About Those Viton Seals, Better Material, And Desired For High Lift Cams... Question Is Do They Fit The l4 Series?? Check This Out: http://forums.hybrid...lve-stem-seals/ Quote Link to comment
Sealik Posted July 23, 2011 Report Share Posted July 23, 2011 I guess you can't get at the valve spring with the cam in? Pretty sure I saw a pry bar type compressor you slip under the cam for leverage. Very fast and the cam stays in. I've been looking for 1...found this http://datsun510.com/photopost/showfull.php?photo=12343 The PN doesn't come up on Nissan Motorsports though 99996-26336 EDIT It is listed in Nissan MS catalog....but not in Nissanparts.cc Kent-Moore.....408 bucks :blink: http://www.costplustools.com/NISSAN-INFINITI-Tools_c_944.html Quote Link to comment
dat521gatherer Posted July 24, 2011 Report Share Posted July 24, 2011 thanks for the write up. you da man! Quote Link to comment
thisismatt Posted July 24, 2011 Report Share Posted July 24, 2011 Nice write up, but capitalizing every word is effing annoying...holy crap. 1 Quote Link to comment
Siqx20 Posted July 25, 2011 Report Share Posted July 25, 2011 Nice write up, but capitalizing every word is effing annoying...holy crap. wow was that intentional? Quote Link to comment
Sealik Posted July 25, 2011 Report Share Posted July 25, 2011 wow was that intentional? Who knows....I PMd him in Feb about capitalization Tried to give him a heads up.... His reply... なに? なにおてるんですか? I managed a couple of neg rep points out of it.... though....:D 1 Quote Link to comment
Laecaon Posted July 25, 2011 Report Share Posted July 25, 2011 Every single post oh his has the first letter of every word capitalized. Even his newest ones. Quote Link to comment
thisismatt Posted July 25, 2011 Report Share Posted July 25, 2011 wow was that intentional? Yes, and it distracts from the usefulness of what would otherwise be good posts. I guess he thinks it's cute, and call me a hater all you want, but it's annoying and makes anyone look like a tool. 3 Quote Link to comment
