Doc Wheeler Posted February 14, 2011 Report Posted February 14, 2011 I'm salvaging a '78 A14 from a '78 B210.. for a Ratsun Rod that will take shape as a '28 Ford roadster pickup tub... First- *Yank every hose and plug every open hole... except? 1. vacuum line to distributor 2. vacuum hose to brake booster Plumb heater hose outlet to inlet (to disable heater) Q? what about the pipe coming out of the exhaust and back to carb plate??? I'm running a GM one wire battery.. and salvaging the electronic ignition using the "transistor ignition mo dual" and after market wiring harness.. Doc- PDX Quote
datzenmike Posted February 14, 2011 Report Posted February 14, 2011 You can use a pipe wrench to remove the EGR tube from the exhaust manifold. Just hacksaw the tube a couple of inches above the fitting. Take the fitting to a hardware store and get a metric pipe thread plug to seal the exhaust. Or you can crush the pipe end with vice grips and roll it to seal. Doesn't look as nice. If using in winter or cold weather in the PNW keep the carb warm air feature connected to the air filter to prevent carb icing. Oh yeah heater deleted:rolleyes: Quote
deadmonkey Posted February 15, 2011 Report Posted February 15, 2011 Not familiar with the A14 but don't plug up the crank vent or else the fumes from the blowback will contaminate the oil and ruin seals over time. At the very least, route that back to the intake. If it has it, you can leave the EGR thermal circuit and that way you will have easier starts in the cold before the engine warms up and then will open when its hot and pull from the fumes from the crank. Quote
Doc Wheeler Posted February 15, 2011 Author Report Posted February 15, 2011 *Bingo that.. and thanks~ *Why.. is there a fuel return loop on this carb engine? May I ignore.. and plumb fuel from tank to pump to carb 'Old school? Doc~ Quote
