Datsun411SSS Posted April 27, 2011 Author Report Share Posted April 27, 2011 I got a chance to drop off a few parts... Intake tube is sitting in place .. air filter will be a tight fit .. also I got a call from the driveshaft place and was told it was ready for pick up ... 3 hours after I dropped it off ! =] driveshaft went in perfect ... More work to come this Thursday ... Here are a few pics ..Shortened and balanced driveshaft: Quote Link to comment
gcmustang Posted April 27, 2011 Report Share Posted April 27, 2011 Keep the pictures coming. it looks like its going together rather quickly. Quote Link to comment
Datsun411SSS Posted April 30, 2011 Author Report Share Posted April 30, 2011 more updates... Thursday i was able to succesfully connect both the upper and lower radiator hose... also connected the intake tube... mounted the fuel pump... ran the feed line (need to run return line) started the wiring... most of the connections under the hood are done... . to do: go to junk yard and get a throttle cable, maf plug, ignition module/coil, shifter handle buy new o-rings for the injectors get exhaust pipe ran and connected finish wiring the can am wiring box Quote Link to comment
Datsun411SSS Posted May 2, 2011 Author Report Share Posted May 2, 2011 So this weekend i headed over to the junk yard and picked up a few missing items i needed.. (Ignition Coil, Ignition module, MAF, and plug for the MAF. . They have all been installed and the return fuel line has been ran and connected. . This coming weekend I will be bolting up the driveshaft, mounting the clutch slave and doing some wiring. . No new pics.. =[ Quote Link to comment
jdmdime Posted May 3, 2011 Report Share Posted May 3, 2011 Heres a pic... ;) I see a 4x4 411 in the back ground.... Haha Quote Link to comment
Datsun411SSS Posted May 3, 2011 Author Report Share Posted May 3, 2011 hahah nice... old school .. Quote Link to comment
Datsun411SSS Posted May 3, 2011 Author Report Share Posted May 3, 2011 here are 2 more... Quote Link to comment
erichwaslike Posted May 4, 2011 Report Share Posted May 4, 2011 are the rims in those pics the same as the ones in ur sig? do u have rubbing issues? Quote Link to comment
MikeRL411 Posted May 4, 2011 Report Share Posted May 4, 2011 Basic question. Where are you going to put the battery? Quote Link to comment
Datsun411SSS Posted May 4, 2011 Author Report Share Posted May 4, 2011 are the rims in those pics the same as the ones in ur sig? do u have rubbing issues? Yea they are the same ones... I just painted them black and polished the lip ... The rear rub a little on hard bumps ..both front and rear fenders have been rolled to help with rubbing .. Quote Link to comment
Datsun411SSS Posted May 4, 2011 Author Report Share Posted May 4, 2011 Basic question. Where are you going to put the battery? I will be putting it in the same location but will be using a Honda size battery ... One of those narrow ones ... I test fitted one and it fit . Quote Link to comment
erichwaslike Posted May 4, 2011 Report Share Posted May 4, 2011 Yea they are the same ones... I just painted them black and polished the lip ... The rear rub a little on hard bumps ..both front and rear fenders have been rolled to help with rubbing .. thanks! i dont think my libres ahng out as far as those but i plan on going low so i was just curious. ur car looks awesome. keep up the good work. Quote Link to comment
Datsun411SSS Posted May 9, 2011 Author Report Share Posted May 9, 2011 Well I didnt work on the car really this weekend... but i did put in the air filter .. lol.. heres the most recent picture of the car with the air filter installed along with the wiring harness. The harness is going into the cabin right behind the fuel lines... kinda hard to see in these pics... ill get some better ones one of these days... Quote Link to comment
freaky510 Posted May 10, 2011 Report Share Posted May 10, 2011 all i can say is WOW!!!!! Love it Quote Link to comment
erichwaslike Posted May 10, 2011 Report Share Posted May 10, 2011 all i can say is WOW!!!!! Love it ur just biased cause its a red 411 Quote Link to comment
Datsun411SSS Posted May 15, 2011 Author Report Share Posted May 15, 2011 UPDATE: Well I can now say the only thing left for this beast to fire up is the wiring and exhaust... today i finished running the return fuel line, bolted up clutch slave, fixed the alternator, ordered and installed a shorter belt for the alternator/waterpump, added some isolators on the front springs since it was metal on metal and screetched really bad, installed the short shifter and bolted up the driveshaft... . tommorow i will be adding in the fluids and start the wiring... Quote Link to comment
Datsun411SSS Posted May 16, 2011 Author Report Share Posted May 16, 2011 more updates... i began the wiring and most of it is done... i just didnt have any wire to give power to the fuel pump nor the starter solenoid... all others are connected to can/am wiring box... i have filled the beast with coolant... filled transmission with oil and all interior is back together... im hoping to take it to an exhaust shop this week so they can run/connect it... and possibly give it its first attempt to start her up... Quote Link to comment
jesusno2 Posted May 16, 2011 Report Share Posted May 16, 2011 Hope all goes well first time I fired my KA everything was way outta whack idle tps maf codes galore! Lol also make sure ya get the air outta the cooling system they tend to air lock easy so watch the temp. Just a heads up in case ya didn't know. Quote Link to comment
Datsun411SSS Posted May 16, 2011 Author Report Share Posted May 16, 2011 Hope all goes well first time I fired my KA everything was way outta whack idle tps maf codes galore! Lol also make sure ya get the air outta the cooling system they tend to air lock easy so watch the temp. Just a heads up in case ya didn't know. Haha thanks for the heads up... I'm ready to expect the worst lol... How did you wire yours ? Quote Link to comment
jesusno2 Posted May 16, 2011 Report Share Posted May 16, 2011 My goons all wired up the old school relay way those fancy boxes wernt around at the time I've cleaned it up a lot since this pic and I'm using the #11 auto ecu. Quote Link to comment
Datsun411SSS Posted May 21, 2011 Author Report Share Posted May 21, 2011 Update: I have completely wired the car up including the fuel pump. All that is left is wire up the alternator to the original harness and get the exhaust connected. All the fluids are in... maybe this weekend i will attempt to get her started up.... I am going to have the exhaust connected tommorow time permitting... if I get it done tommorow, I shall try cranking her on... so close yet so far... . Just to make sure, when wiring the can am wiring box, i de-pin the black with white stripe wires (109,38 & 47) from the ecu connector and connect them to the can am box right?? Quote Link to comment
Datsun411SSS Posted May 22, 2011 Author Report Share Posted May 22, 2011 More updates... I got the exhaust done today along with the o2 sensor... It got ran straight down instead of thru the inner fender... It took the guy about 4 hours from beginning to end... Came out pretty good ... I will get pictures tomorrow ... All is done pretty much ... Just haven't fired it up yet... I opened the key and all the lights on the can am wiring box came on ... So far good signs... Tomorrow it will get its first attempt to fire up... Wish me luck guys... Quote Link to comment
jesusno2 Posted May 22, 2011 Report Share Posted May 22, 2011 good luck my first attempt failed lol but i didnt make anything permanent till i know all was well! Quote Link to comment
Datsun411SSS Posted May 22, 2011 Author Report Share Posted May 22, 2011 Do you know how to bypass the neutral safety switch ? Quote Link to comment
erichwaslike Posted May 22, 2011 Report Share Posted May 22, 2011 just wire it straigth to ground. thats all its looking for, or u can wire it to ur old clutch postion switch so it wont crank without the clutch being pushed in Quote Link to comment
