72nismo Posted February 10, 2011 Report Posted February 10, 2011 Is there a write up somewere of how to take off and reinstall your steering box?? Can someone direct me to the thread?? Can't seem to find anything. Thanks Quote
datzenmike Posted February 10, 2011 Report Posted February 10, 2011 Remove pinch bolt holding the column U joint to the steering box splined input shaft. Remove the pitman arm to sector shaft nut and lock washer and using a special puller tool, remove the pitman arm. The pitman arm remains on the car connected to the steering linkages. OR Remove the cotter pin and nut from the ball joint on the other end of the pitman arm and using a ball joint separator remove the ball joint. The pitman arm remains with the steering box. Now unbolt the 3 securing bolts that hold the steering box to the frame and lift out. Quote
Icehouse Posted February 10, 2011 Report Posted February 10, 2011 Remove the ball joint is WAY easier than taking the pitman arm off! The spins on the steering shaft are most likely rusty so they will have a bit of resistance. Sometimes smacking a flat head screwdriver and leaving it in the colum U-joint can help. Change the fluid when you have it out would also be a good idea :) Quote
hang_510 Posted February 10, 2011 Report Posted February 10, 2011 The pitman arm remains with the steering box. i think every box ive replaced, it was still attached Quote
72nismo Posted February 13, 2011 Author Report Posted February 13, 2011 What kind of fluid and how much fluid goes in the steering box?? I'm about to try to disconnect box. Quote
datzenmike Posted February 13, 2011 Report Posted February 13, 2011 Well the 610/710 box is similar to the 510 and about 1/3 liter is recomended or 5/8 US pint. I would just fill up and leave a space at the top. The oil to use is the same used in the standard transmission... GL-4 80 W 90 weight should do. Do NOT use GL-5 differential oil!. Quote
hang_510 Posted February 13, 2011 Report Posted February 13, 2011 i also add in a little molybdenum disulfide grease Quote
72nismo Posted February 14, 2011 Author Report Posted February 14, 2011 I took steering box off this morning. Everything seemed pretty simple not as difficult as I first thought. Thanks fellas for the info Quote
