521 part # thread
nismo dr
Thought I would compile the part numbers I have found.
Nissan King Pin Kit - 40022-14825
Nissan Fulcrum Pin Kit - 54502-20525
Nissan KA24 Oil Pump - -15010-40F00
L motor
Nismo Composite Head Gasket
88.5mm Bore, 1.5mm compressed thickness
11044-A7651
Nismo Roller Pilot Bearing
32202-09500
Nismo Competition Valve Springs
99996-M1046
Nismo 8 Position Adjustable Cam Sprocket
13024-E4621
KYB Gas-A-Just Rear Shocks - KG4605A - Same product in CarQuest box 1844257
KYB Gas-A-Just Pinto Front Shocks - KG4511
MOOG Center Link - DS846
Mallory Distributor (points) - 4558901
Addco Rear Sway Bar Kit - 228
Centerforce Dual Friction Clutch Kit 200mm - DF506276
Wagner Amber Fog Lamps - 4412A
Centerforce Throw Out Bearing - 1602
Grant Steering Wheel Installation Kit - 4591
its a start
  • Replies 138
Hmm very well then. I guess we should just message you with part numbers, so you can edit your original post. Otherwise sooner or later this will be 10-20 pages long and it would be a PITA to find a part number...
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
  • 3 months later...
not part numbers per se but I'm not scanning hundreds (feels like) of pages, figured even if we could have pics we could point to and say "that part, #36" might be helpful, and if its not, hell we can make a coloring book
  • 1 month later...
so i'm a little unclear on the wheel bearing part numbers so i'll just post it here.... out of all the threads sprinkled throughout ratsun i keep reading that all the numbers listed on all the autopart sites [rockauto, carquest, drivewire..etc] are wrong resulting in a wrong part
i recently bought some nachi brand part number 40210-73000 and also has 32kbs1 and 830425 stamped on the box. they are supposed to be 521 inner bearings and races.
did i do good? if not is there a sweet spot that has these elusive wheel bearings?
sorry if this is redundant but all the searching i came up with still hasn't left me clear on this.
edit: i haven't tried installing them yet as i do not have all the parts for my disc brake swap yet otherwise i'd just be asking "hey, where do i get these?" laugh.gif
the factory #s
inner (the unobtanium one) 40211-32200
outer 40215-p0100
haven't found a sweet spot, come up on ebay once in a while for around $200+, or you can buy mklotz spacers that let you run more readily available bearings
I actually found a source in signapore thanks to boxboy. PM if anyone wants the guys email. he has the original KOYO 32KB02 inner wheel bearings.
Sorry to litter the thread Dr.
But at what price are these bearings?
And how long is the wait for shipping?
Bearing adapters from Klotz, and easily-obtainable 620 bearings seems like a smart way to swing.
20 dolla each. 2 weeks by air mail. 20 dolla shipping. So your looking at 60 dolla total.
