1969510 Posted February 9, 2011 Report Share Posted February 9, 2011 Ok so im putting a el dizzy in with allison box.. it belonged to me a few years ago and i dont remember what wires go where its in a 69 witch is the same that it was in before. I'm prob just KA stupid now.Its gong in my l18 wagoon. had the motor running fine then attepted to put in the el dizzy. not so much worried about timing as much as th specific wiring. any help would much appreciated. Quote Link to comment
MicroMachinery Posted February 9, 2011 Report Share Posted February 9, 2011 its in a 69 witch I forget what the differences are between a 69 and 70 Witch.. can you explain? I also know that there was an optional Black Cat that came in the 71, but that's irrelevant to your situation, of course. Quote Link to comment
banzai510(hainz) Posted February 9, 2011 Report Share Posted February 9, 2011 you still have a point set up in there? yes you need to worry about timming as not all the dizzys roto lock down in the same spot. You have a EI coil? or you want to run the stock coil with the ballast resisitor.? Quote Link to comment
1969510 Posted February 10, 2011 Author Report Share Posted February 10, 2011 I think its the first witch.... and I do have the optional Black Cat! Lucky me.. LOL. Quote Link to comment
1969510 Posted February 10, 2011 Author Report Share Posted February 10, 2011 I have the allison box with petronix el dizzy. I'm going to be running the stock coil w/ballast. Thanks, Quote Link to comment
MicroMachinery Posted February 10, 2011 Report Share Posted February 10, 2011 I think its the first witch.... and I do have the optional Black Cat! Lucky me.. LOL. :rofl: Quote Link to comment
banzai510(hainz) Posted February 10, 2011 Report Share Posted February 10, 2011 have the allison box with petronix el dizzy. I'm going to be running the stock coil w/ballast. Thanks WHAT!!!!!!!!!!! the Pertronix DOESNT need a Allison box its all self contained. the allison should have its own shutter for the dist and a remote box. personall the Pertronix takes care all of this. allison was bought out by CraneCams and they called it the XR700 ,crane Cams went bankrupt a few years ago but soem of the xr700s mgiht still be out there NEW. Quote Link to comment
1969510 Posted February 11, 2011 Author Report Share Posted February 11, 2011 Ok so I was a little lost.:huh: Hainz you are very correct as usual it does just have the shutter in the dizzy. I got it all hooked up last night. Thanks for the help you guys are great! Quote Link to comment
banzai510(hainz) Posted February 12, 2011 Report Share Posted February 12, 2011 read the instructions carefully. I would assume you still need your ballast resisitor and coil. with the allsison setup. Iseem people install mallory Unilites and keep blowing up their modules. but if one reads the instruction you use your stock set up. Thats mean point coil with the ballast resistor.(do not remove the ballast resisitor) Quote Link to comment
