datsunfish Posted February 2, 2008 Report Share Posted February 2, 2008 Hey guys.I will be picking this up next weekend and could use a little help. A naps z 24 block and head with the throttle assist tbi kinda thing and fuel pump. Basically I want to do a LZ hybrid.I know all the draw backs that I am sure you will all tell me about.The piston walls are thin so dont overheat.The deck height is taller and will require a modified timing cover.Crank may not be counter balanced like a L series. What I am most curious about is the tbi setup.If it bolts directly to as naps manifold than it should bolt to a L mani.Right?As easy as a high pressure pump and lines,computer brain and o2 sensor.Right? What would be the best head.I assume a u67 since it has large ports and is open chamber.I imagine a peanut would be to high compression.I have every L series head other than the n68 and 219 sss. I am going to use it in my 510 with auto tranny to get a better smooth get up and go and all the torque I would ever need for hauling those groceries.:cool: Any tips,advice,insight or pics of your own setup would be great.I am going to do this regardless so dont try to talk me out of it.:fu: Quote Link to comment
datsunaholic Posted February 2, 2008 Report Share Posted February 2, 2008 Last I knew, the TBI setup doesn't fit the carb manifold. It LOOKS the same, but I recall the TBI setup has one of the 4 bolts "offset" so it's not a rectangular pattern. However I've actually never seen one apart. Quote Link to comment
datzenmike Posted February 2, 2008 Report Share Posted February 2, 2008 The TBI does not fit the Z24 carb manifold. It's common for D-21 and WD-21 owners to scoop up Z24 intakes for carb conversions on their Z241 motors. The TBI won't fit the L series manifold without drilling and taping. If it was easy, it would have been done. Not impossible though I guess. Don't know about thin cylinders, but it's not advisable to overheat any aluminum head engine. The Z24 block is known for blowing the head gasket every 100 K miles. Quote Link to comment
datsunfish Posted February 3, 2008 Author Report Share Posted February 3, 2008 I shall modify it to fit the L mani.Or just run a weber. Quote Link to comment
RacnJsn95 Posted February 3, 2008 Report Share Posted February 3, 2008 The Z24 is taller than the Z22/Z20/L20b, if you try to run an L head, and use the L20b timing cover, you'll find it is about .75" too short. Quote Link to comment
jovial_cynic Posted February 3, 2008 Report Share Posted February 3, 2008 The Z24 is taller than the Z22/Z20/L20b, if you try to run an L head, and use the L20b timing cover, you'll find it is about .75" too short. This is true. However, I've read of people simply blocking up the gap and not running into any problems. Quote Link to comment
datsunfish Posted February 3, 2008 Author Report Share Posted February 3, 2008 Original post.I am aware of deck height issues.I got a few ideas. Quote Link to comment
hang_510 Posted February 4, 2008 Report Share Posted February 4, 2008 i used the Z24 cover. it would be easy to modify the Z24 cover, if you can weld, to mate w/ the L head. Quote Link to comment
laniadude Posted February 12, 2008 Report Share Posted February 12, 2008 is this an easy swap??? I want to put a Z24 into my truck also...do the drivelines have to be replaced?? does it line up to the L series mounts?? Quote Link to comment
