brodster Posted February 3, 2011 Report Share Posted February 3, 2011 I would love to get 15" rims and upgrade to disc brakes, but I want to keep the stock wheels on my 521. I was reading a DQ article about using NISMO greenstuff pads to boost the 510 performance. Is there anything equivalent for the 521? Stock nissan shoes the best (if they are available)? Thanks. I am open to anything that will allow me to keep my stock wheels. Quote Link to comment
nismo dr Posted February 3, 2011 Report Share Posted February 3, 2011 I would love to get 15" rims and upgrade to disc brakes, but I want to keep the stock wheels on my 521. I was reading a DQ article about using NISMO greenstuff pads to boost the 510 performance. Is there anything equivalent for the 521? Stock nissan shoes the best (if they are available)? Thanks. I am open to anything that will allow me to keep my stock wheels. mklotz's brake kit lets you run the stock 14"s, I believe Quote Link to comment
nismo dr Posted February 3, 2011 Report Share Posted February 3, 2011 http://community.ratsun.net/topic/11459-disc-brake-kits-521520320620/ Quote Link to comment
yello620 Posted February 3, 2011 Report Share Posted February 3, 2011 You can also have your shoes relined with a performance minded material at places like "ott's friction supply", they are located in portland. Quote Link to comment
brodster Posted February 3, 2011 Author Report Share Posted February 3, 2011 mklotz's brake kit lets you run the stock 14"s, I believe I was looking at the other kit I think. Thanks! Quote Link to comment
Aaron Posted February 3, 2011 Report Share Posted February 3, 2011 Yes, Mikes kit will fit but it took a little grinding on the caliper. See photos below. Had to source 620 hubs to fit on the stock rims, 720 hubs can be turned down to fit but the 620's fit without modification. Nice kit easy to install, the hardest part was the grinding to fit the wheel with enough clearance with the stock rims. Hears the grinding on the caliper. Stock rims back on. Quote Link to comment
brodster Posted February 4, 2011 Author Report Share Posted February 4, 2011 Looks great. Thanks. I will be ordering a kit from Mike really soon. I need to source some 620 hubs though. The junkyard seem to be much more deep in 720's though. That may be an easier option for me. Quote Link to comment
mklotz70 Posted March 20, 2011 Report Share Posted March 20, 2011 The mid '85 or older 720 hubs should not require any machining. After '85 they used the same big center hole as the hardbody. Prior to '83, they used the same hub as the 620(disc). Aaron...pm sent about the grinding :) Quote Link to comment
mklotz70 Posted August 8, 2011 Report Share Posted August 8, 2011 Just happened across this....thought I'd add some info for anyone else that reads it. The grinding was required only with the stock rims. The alternative is to use a 1/4" wheel spacer if you don't want to grind on the caliper. For more info on the installation of the kit..... http://www.bluehandsinc.com/truck-kit-install.html Quote Link to comment
