sycloned916 Posted February 2, 2008 Report Share Posted February 2, 2008 Got some new 24's for my 1967 Datsun 520 and couldn't find lug nuts for it in my shop had 1/2,9/16,14X1.50,12x1.50,and 12x1.25.None seem to work really good but the 12x1.25 but was alittle lose.http://i88.photobucket.com/albums/k198/Butterb_2006/Dat.jpg Quote Link to comment
phatdave Posted February 2, 2008 Report Share Posted February 2, 2008 :D....should be 12 x 1.25...at least thats whats on my 620. I would think they are the same. Quote Link to comment
sycloned916 Posted February 2, 2008 Author Report Share Posted February 2, 2008 I'll try them again.They just feel alittle lose when i put them on,but when they get to the rim they get tight,just don't want them to unscrew off when I'm driving:confused: Quote Link to comment
fiveoneohray Posted February 2, 2008 Report Share Posted February 2, 2008 No I just had the same problem they are the same as roadster. 7/16 20 Quote Link to comment
datsunaholic Posted February 2, 2008 Report Share Posted February 2, 2008 They aren't metric, they're not the same as a 620. As ray said, 7/16x20. I just bought a full set of shanks for mine. Quote Link to comment
pl521sss Posted February 2, 2008 Report Share Posted February 2, 2008 They aren't metric, they're not the same as a 620. As ray said, 7/16x20. I just bought a full set of shanks for mine. buy them online http://www.ezaccessory.com/Acorn_Lug_Nuts_s/1.htm A lot cheaper and get spares. You'll easily spend $40 at least from the local shops Quote Link to comment
sdsurf Posted February 2, 2008 Report Share Posted February 2, 2008 http://www.ezaccessory.com/Acorn_Lug_Nuts_7_16_Thread_p/1202.htm Will these work with titan wheels OR stock wheels on a 521? Quote Link to comment
pl521sss Posted February 2, 2008 Report Share Posted February 2, 2008 http://www.ezaccessory.com/Acorn_Lug_Nuts_7_16_Thread_p/1202.htm Will these work with titan wheels OR stock wheels on a 521? I used the Bulge Acorn type on my Frontier wheels. So it won't dig in on the wheels. Regular acorn will. I would thing the Titan wheels would be similar. Don't quote me on this cause I don't have Titan wheels. Quote Link to comment
yello620 Posted February 2, 2008 Report Share Posted February 2, 2008 Acorn nuts sometimes do have a tendancy to dig into the wheels a little. The bulge nuts do help fix this problem. The only small problem with the bulge nuts is that they are usually a 3/4 hex instead of the stock 13/16" hex. Not a big deal, you can get adapter specifically for this problem. Just making sure that you have a proper lug wrench in the vehicle is all the adapter amounts too. Jason Quote Link to comment
sycloned916 Posted February 5, 2008 Author Report Share Posted February 5, 2008 I'll grab a set of 7/16x20,I just tried the 12x1.25, No Go on them. 7/16x20 it is.Thanks All! Quote Link to comment
fiveNdime Posted February 8, 2008 Report Share Posted February 8, 2008 I had this same problem on my 521. The stock ones are 7/16. I had a few others mixed into my situation so I pulled all of them out and installed new ones from napa 12mm x 1.50 thread pitch. They are about a 1/2" longer which is good cause the new aluminum wheels are thicker. I had to drill out for them just a fuzz. They press in and work just like stock. Quote Link to comment
