Lude944 Posted January 30, 2011 Report Share Posted January 30, 2011 I am looking for item #9 a rear brake extension link. 1 Link to comment
Lude944 Posted January 30, 2011 Author Report Share Posted January 30, 2011 (edited) ... Edited January 30, 2011 by Lude944 1 Link to comment
izzo Posted January 30, 2011 Report Share Posted January 30, 2011 Part 44030-32200 www.nissanparts.cc under 3 bucks 1 Link to comment
datzenmike Posted January 30, 2011 Report Share Posted January 30, 2011 Also used on the 620 through '79 and the 720 through mid '81. Probably changed when self adjusters were added. Someone must have one laying around. Try the dealer under $5. 1 Link to comment
Lude944 Posted January 30, 2011 Author Report Share Posted January 30, 2011 Part 44030-32200 www.nissanparts.cc under 3 bucks thanks im ordering it right now. 1 Link to comment
Lude944 Posted January 30, 2011 Author Report Share Posted January 30, 2011 by the way how did you find the part number? 1 Link to comment
datzenmike Posted January 30, 2011 Report Share Posted January 30, 2011 Sorry, I have to protect my sources. Ahhh I see izzo replied also. 1 Link to comment
izzo Posted January 30, 2011 Report Share Posted January 30, 2011 by the way how did you find the part number? www.carpartsmanual.com 1 Link to comment
Lude944 Posted March 12, 2011 Author Report Share Posted March 12, 2011 Update so after waiting an entire month to receive the part i got around to putting it on last week and was all set to go test drive when i go to depress the clutch and its STUCK!!!!...So any ideas how to get it unstuck??? I checked out the slave cylinder the push rod was a bit rusty so i cleaned it and hit it w/WD-40 it doesnt appear to be stuck even with the rust. Then i moved to the master cylinder the fluid was low so I topped it off. Didnt see any leaks in the lines. The pedal it fully extended and has no play at all. I think its the master cylinder. But thats just a really bad guess. 1 Link to comment
