521 Johnny Posted January 21, 2011 Report Share Posted January 21, 2011 ITS A 1972, JUST PICKED IT UP IN LAUGHLIN THIS PAST WEEKEND, ITS A FRAME OFF BUILD, ALREADY TORN DOWN AND CHOPPED UP. ITS GETTING A NEW REAR CHASSI, CUSTOM FLOOR AND TUNNEL BODY DROP, SHAVING ROCKER PANELS OFF, IT HAS AN L20B WITH A 6 SPEED MANUAL TRANNY, PUTTING IT ON 18 TITAN WHEELS FOR NOW HOPING TO BUILD IT TO FIT 20'S, LET ME KNOW WHAT YOU THINK! IVE BEEN BUILDING OFF ROAD RACE PARTS AND VEHICLES FOR 10 YEARS , KINDA NEVER WAS INTO THE MINI TRUCK SCENE, BUT I LOVE THIS LIL TRUCK! Quote Link to comment
pharouh Posted January 21, 2011 Report Share Posted January 21, 2011 WHY ARE YOU SHOUTING? :( Pics please.. Quote Link to comment
521 Johnny Posted January 21, 2011 Author Report Share Posted January 21, 2011 SHOUTING? ITS CALLED CAPS LOCK 1 Quote Link to comment
nismo dr Posted January 21, 2011 Report Share Posted January 21, 2011 where did you get the 6 speed? I want one! Quote Link to comment
521 Johnny Posted January 21, 2011 Author Report Share Posted January 21, 2011 It came with it, got lucky, the whole truck was super straight and only a lil door rust on the passenger side Quote Link to comment
521 Johnny Posted January 21, 2011 Author Report Share Posted January 21, 2011 This was it last sunday when i got it home, 1-16-2011 was the start date for this and it will be a fast build, the guy in the red hat (Jimmy) owns this truck, i used it for inspiration. Quote Link to comment
521 Johnny Posted January 21, 2011 Author Report Share Posted January 21, 2011 also here is a link to my other truck build thats almost finished http://www.dezertrangers.com/vb/dr-rides/129575.htm Quote Link to comment
Wide14u Posted January 22, 2011 Report Share Posted January 22, 2011 good looking truck but a its a 5 speed plus reversed is a 6 speed Quote Link to comment
521 Johnny Posted January 22, 2011 Author Report Share Posted January 22, 2011 IF THATS THE CASE THEN THIS IS A 7 SPEED, TRUST ME ITS A 6 SPEED Quote Link to comment
pharouh Posted January 22, 2011 Report Share Posted January 22, 2011 I know nothing about transmissions, you guys figure it out. cool truck though. :thumbup: Quote Link to comment
PurePontiacKid Posted January 22, 2011 Report Share Posted January 22, 2011 I LOVE CAPS LOCK Quote Link to comment
datrod Posted January 22, 2011 Report Share Posted January 22, 2011 WELCOME TO RATSUN. YOU GOIN TO FF IN MARCH ? Quote Link to comment
NCRmtrsprts510 Posted January 22, 2011 Report Share Posted January 22, 2011 MORE oics of prerunner, cant see the oics on the other forum because we are not members. Quote Link to comment
BEEBANI Posted January 22, 2011 Report Share Posted January 22, 2011 NOT TRYING TO BE ONE OF "THOSE" GUYS, BUT THAT IS CLEARLY AN L-SERIES TRANNY, WHICH WAS NEVER PRODUCED AS A 6 SPEED. KEEP UP THE GOOD WORK ANYWAY! Quote Link to comment
wayno Posted January 22, 2011 Report Share Posted January 22, 2011 NOT TRYING TO BE ONE OF "THOSE" GUYS, BUT THAT IS CLEARLY AN L-SERIES TRANNY, WHICH WAS NEVER PRODUCED AS A 6 SPEED. KEEP UP THE GOOD WORK ANYWAY! I don't know if nissan made a 6 speed transmission that bolted to the 1980 L20b case such as the napZ type transmission which will all the way threw 86, but if you expand/enlarge the tranny in the area where the tailshaft bolts to the front case, the tail section is abnormally long where the 5th and rev. gears are, there is also a drain plug in a strange place/tilted, maybe a napZ type transmission was bolted to the L block(been told it can be done) and if you look really close to the bottom of the tilted tailshaft there is a flat area that looks like it could have a drain plug or something, this flat area doesn't exist on my 5 spds. That whole transmission is tilted to about 10:30 on the clock. I wonder if the stick shift is tilted also. I'm thinking this is some kind of hybrid transmission. Did nissan make a 6 speed in the 90s? wayno Quote Link to comment
Rustina 510 Posted January 22, 2011 Report Share Posted January 22, 2011 Wow if it is a six speed plus rev tranny, I really want to know where I can find one Quote Link to comment
BEEBANI Posted January 22, 2011 Report Share Posted January 22, 2011 I don't know if nissan made a 6 speed transmission that bolted to the 1980 L20b case such as the napZ type transmission which will all the way threw 86, but if you expand/enlarge the tranny in the area where the tailshaft bolts to the front case, the tail section is abnormally long where the 5th and rev. gears are, there is also a drain plug in a strange place/tilted, maybe a napZ type transmission was bolted to the L block(been told it can be done) and if you look really close to the bottom of the tilted tailshaft there is a flat area that looks like it could have a drain plug or something, this flat area doesn't exist on my 5 spds. That whole transmission is tilted to about 10:30 on the clock. I wonder if the stick shift is tilted also. I'm thinking this is some kind of hybrid transmission. Did nissan make a 6 speed in the 90s? wayno I don't think they did, but you could be right, could be some hybrid of some sorts. You can bolt a napz tranny to an L-motor, but I think the tilt is wrong. The napz bellhousing is what I used to bolt the 280zx tranny to my ka24e motor when I built my truck to get the tilt right. Quote Link to comment
wayno Posted January 23, 2011 Report Share Posted January 23, 2011 I don't think they did, but you could be right, could be some hybrid of some sorts. You can bolt a napz tranny to an L-motor, but I think the tilt is wrong. The napz bellhousing is what I used to bolt the 280zx tranny to my ka24e motor when I built my truck to get the tilt right. If you use the 1980 720 4 or 5 speed front case(L20b), you can put it on any of the napZ 5 speed transmissions, if you put the 80 case on a 85 shortshaft 2wd 720 transmission, you can use it in a 521 and have the shifter come out the stock shifter hole and the tilt will be right. wayno Quote Link to comment
521 Johnny Posted January 24, 2011 Author Report Share Posted January 24, 2011 I have new pics, waiting to upload them! Quote Link to comment
