DAT510 Posted August 5, 2011 Report Share Posted August 5, 2011 ya id be going from an l16 to an l20b. are l16 flywheels 5 or 6 bolt? 5. Quote Link to comment
jon521 Posted August 5, 2011 Report Share Posted August 5, 2011 thanks. ive been talking about this in my truck thread: http://community.ratsun.net/topic/32940-1971-521/page__st__20 hainz was saying i need a T/O bearing collar, since the L16 flywheel, clutch, T/O bearing etc is different from the L20b, and i dont exactly know what the collar is or does..... Quote Link to comment
DAT510 Posted August 5, 2011 Report Share Posted August 5, 2011 thanks. ive been talking about this in my truck thread: http://community.rat...21/page__st__20 hainz was saying i need a T/O bearing collar, since the L16 flywheel, clutch, T/O bearing etc is different from the L20b, and i dont exactly know what the collar is or does..... i believe the throwout bearing is what actuates the clutch's diaphragm. the collar is that part that has the bearing on it. http://www.google.com/imgres?q=throw+out+bearing+collar&um=1&hl=en&biw=1440&bih=787&tbm=isch&tbnid=q24X1mtaL0z5rM:&imgrefurl=http://www.mgexperience.net/phorum/read.php%253F1,916936&docid=XMtd3Iok1L9ejM&w=500&h=115&ei=cmE7TpmQLaPViAL93cHoCw&zoom=1&iact=hc&vpx=123&vpy=481&dur=334&hovh=76&hovw=332&tx=267&ty=35&page=3&tbnh=43&tbnw=189&start=48&ndsp=27&ved=1t:429,r:0,s:48 Quote Link to comment
jon521 Posted August 5, 2011 Report Share Posted August 5, 2011 so if i get a clutch kit, i will still need to buy a collar some where? Quote Link to comment
DAT510 Posted August 5, 2011 Report Share Posted August 5, 2011 not sure, Hainz or Datzen will definitely know. Quote Link to comment
DAT510 Posted August 5, 2011 Report Share Posted August 5, 2011 You can order all the parts you need from here, but check with Hainz first http://www.datsunparts.com/Clutch Quote Link to comment
banzai510(hainz) Posted August 5, 2011 Report Share Posted August 5, 2011 225mm clutches have a different diaphram height thus a different size T/O colloar will be used compared to the stock L16 200mm clutch set ups. I think Rockauto.com look on the later L20trucks and I believe they sell the whole bearing and with a colloar on one of them. Unless you have a Datsun buddy that has this parts avail. If wrong T/O bearing collar is installed it could engage or not engage the clutch correctly Datzenmike is more of a expert as I only use 200mm stuff(or Roadster pressure plate, same diaphrame height as stock L16 clutch) Quote Link to comment
dat521 Posted August 13, 2011 Report Share Posted August 13, 2011 So this is what happened i bought the l20b and the guy who i bought it from said he would install it for me, so it took him about a day. the truck was running fine but the ride was shaky and the engine had a horrible rattle so i took it to my mechanic and his telling me my distributor and head are fucking up! Quote Link to comment
'70 521 L16 Posted August 13, 2011 Report Share Posted August 13, 2011 have a timing light? its worth re-timing and adjusting the card because of the new engine if you haven't done it yet and it's possible that that could fix it. constant rattle? we need more details! Quote Link to comment
datzenmike Posted August 13, 2011 Report Share Posted August 13, 2011 225mm clutches have a different diaphram height thus a different size T/O colloar will be used compared to the stock L16 200mm clutch set ups. I think Rockauto.com look on the later L20trucks and I believe they sell the whole bearing and with a colloar on one of them. Unless you have a Datsun buddy that has this parts avail. If wrong T/O bearing collar is installed it could engage or not engage the clutch correctly Datzenmike is more of a expert as I only use 200mm stuff(or Roadster pressure plate, same diaphrame height as stock L16 clutch) Many years ago (over 30) i swapped an L20B into my 521. I didn't know about the different clutch/throwout bearing collar sizes back then. Luckily the L20B was from a buddy's car so it was a 200mm. I used the 521 collar and it worked just fine. I don't remember changing the oil pan to the L16, don't think I did. :confused: Quote Link to comment
dat521 Posted August 16, 2011 Report Share Posted August 16, 2011 yea we timed it but it still shakes like a crack head Quote Link to comment
1970 521 truck Posted March 5, 2012 Report Share Posted March 5, 2012 I've got the l20b in my 521 I used the l16 pan and clutch set up I pulled a 5 speed out of a late model truck bolted right up with no problem at all as well as I used the head off of the l16 do to the split layout on the intake and exhaust manifold all works just fine in the truck I will.say it hauls some but on the street and nice on the hwy with the 5 speed. Quote Link to comment
mrbigtanker Posted March 5, 2012 Report Share Posted March 5, 2012 So a newer 5 speed is 225mm correct.And as for oil pan thats for drag link issues also correct. Quote Link to comment
Paul hieb Posted February 4 Report Share Posted February 4 Side question but curious doing the L20B swap in a 521 do I need to get that engine harness and install that into the 521 and is it fairly simple to do or does it take some figuring. Or does the original 521 harness work with that engine. Quote Link to comment
datzenmike Posted February 4 Report Share Posted February 4 The L20B is the L16s big brother. Looks identical other than the top of the block is 2cm taller. The 521 electrical system and wiring will work with the L20B. I put a 610 or 710 car L20B into my 71 521 back in the mid '70s 1/ If the L20B is a '78-'79 it will have an electronic ignition so a couple of very minor changes to the coil and ballast. 2/ You will need to swap the 521 oil pan and pick up tube and the 521 engine brackets onto the L20B. 3/ If the L20B is from a car it likely has a linkage throttle set up so again a minor part swap from the L16 carburetor. 4/ Use the L16 exhaust manifold and if a '75-'77 L20B use the L16 intake as well. 5/ If a car L20B the 521 release bearing collar will match your 521. If from a truck you will need the proper release bearing collar for a 225mm clutch. 1 Quote Link to comment
Stoffregen Motorsports Posted February 4 Report Share Posted February 4 14 hours ago, Paul hieb said: Side question but curious doing the L20B swap in a 521 do I need to get that engine harness and install that into the 521 and is it fairly simple to do or does it take some figuring. Or does the original 521 harness work with that engine. Hi Paul. Welcome. I am in Cool. If you're ever up this way, hit me up! 1 Quote Link to comment
banzai510(hainz) Posted February 4 Report Share Posted February 4 egines as pretty much the same use the 521 oil pan and oil pick up. you can use the L16 distrributor and dist mounbt and should be the same hook up. 1 Quote Link to comment
Paul hieb Posted February 5 Report Share Posted February 5 23 hours ago, Stoffregen Motorsports said: Hi Paul. Welcome. I am in Cool. If you're ever up this way, hit me up! Oh nice. Yea I actually live in El dorado so about 20 mins from cool give or take. 1 Quote Link to comment
