bbqbill Posted January 7, 2011 Report Share Posted January 7, 2011 i`ve taken the smog stiff off my 76 l20b and was wondering if there are any tuning changes i need to know , or does it not make a diff. Quote Link to comment
420n620 Posted January 7, 2011 Report Share Posted January 7, 2011 your good to go, just amke sure u have plugged up any vacuum hoses/lines. Quote Link to comment
DanielC Posted January 7, 2011 Report Share Posted January 7, 2011 Leave the PCV system on the engine! Quote Link to comment
Wide14u Posted January 7, 2011 Report Share Posted January 7, 2011 how is it doing Quote Link to comment
bbqbill Posted January 8, 2011 Author Report Share Posted January 8, 2011 i changed the head gasket and timing chain,pulled the smog stuff ,now i cant keep it running? Quote Link to comment
Llittle_Llama Posted January 12, 2011 Report Share Posted January 12, 2011 You might have a Vac. leak, just a thought. I would start with that if it takes throttle to keep it running. Quote Link to comment
dat77sun Posted January 12, 2011 Report Share Posted January 12, 2011 probly a vacuum leak, or maybe somethin in the carb Quote Link to comment
datzenmike Posted January 12, 2011 Report Share Posted January 12, 2011 There are only a few ways to do this right, Post a picture of what you've done. Quote Link to comment
justin 620 Posted January 16, 2011 Report Share Posted January 16, 2011 If it's the stock Hitachi, there's probably a problem in the carb, and those ones are virtually immpossible to troouble shoot. If you've got all the smog off, you might as well go with a Weber, way more reliable. Getting rid on smog is a bitch, and like Mike said, there's only one way to do it propperly. Quote Link to comment
bbqbill Posted February 6, 2011 Author Report Share Posted February 6, 2011 i found the vac.leak.runs good now. started on the drivers side floor. Quote Link to comment
epfrz Posted February 10, 2011 Report Share Posted February 10, 2011 The weber works great with the smog stuff off. I have also heard that you need to make sure the air injectors in the exhaust manifold are removed and plugged to get the engine running at its best. Quote Link to comment
bbqbill Posted February 11, 2011 Author Report Share Posted February 11, 2011 The weber works great with the smog stuff off. I have also heard that you need to make sure the air injectors in the exhaust manifold are removed and plugged to get the engine running at its best. i found the plugs at a a/c shop,their a standerd size Quote Link to comment
jbirds510 Posted February 15, 2011 Report Share Posted February 15, 2011 if you are lookin to get rid of the smog stuff let me know.Here in the REPUBLIK of KALIFORNIA we still have to smog these old rigs! Quote Link to comment
