DISLEXICDIME Posted December 26, 2010 Author Report Share Posted December 26, 2010 well I drove it to day man it is loud! I think I am going to have to redo the front suspension either it is bottoming out or I am getting really bad bump steer. I will probably see if I can find some mr2 agx and shorten the strut tube 80mm. Buy some camber plates and t3 tc rods like my 4 door had. The back feels good though. Needs an alignment as well. i only drove it around the block and already had a guy cheering me on lol Quote Link to comment
philcas1987 Posted December 27, 2010 Report Share Posted December 27, 2010 Whoo whoo!!!! Quote Link to comment
DISLEXICDIME Posted December 27, 2010 Author Report Share Posted December 27, 2010 I need 2 40 series 16's so i can start driving this thing Quote Link to comment
Rustina 510 Posted December 27, 2010 Report Share Posted December 27, 2010 That is so awesome, to be able to drive it so soon must have been great. Quote Link to comment
The Dat-side Posted December 28, 2010 Report Share Posted December 28, 2010 sweet if any one has 15x8 0 offset xxr 002 they want to sell let me know These are 16x8 0 off. http://portland.craigslist.org/mlt/pts/2131887855.html Quote Link to comment
xvi00 Posted December 28, 2010 Report Share Posted December 28, 2010 Like Dat-side above posted these 16 x 8 would look bloody unreal on your car. Great looking car you will end up with. Quote Link to comment
DISLEXICDIME Posted December 28, 2010 Author Report Share Posted December 28, 2010 These are 16x8 0 off. http://portland.craigslist.org/mlt/pts/2131887855.html I already have 3 of those they don't have the offset I need I have to use a spacer to make them look right Quote Link to comment
Bleach Posted December 28, 2010 Report Share Posted December 28, 2010 7+ years ago there was a guy in Vancouver that had a white 2-door box flared 510. I wonder if this is the same one. Mike may still know him. I think he has a blue 521 now? He hasn't been to Canby or on a forum in about 5 years though. Quote Link to comment
DISLEXICDIME Posted December 28, 2010 Author Report Share Posted December 28, 2010 This is not that car. I wish it was lol. Quote Link to comment
DISLEXICDIME Posted January 1, 2011 Author Report Share Posted January 1, 2011 Got the tire mounted Then phill came over to help me bleed the brakes but we could not seem to get the pedal as firm as we wanted it . Then we noticed that since there where no bumpsteer spacers installed with the zx brakes they where hitting so we swapped the left side to the right so that the caliper is in the front and does not hit any thing. But I think the actual calipers are seezing up Quote Link to comment
yello620 Posted January 1, 2011 Report Share Posted January 1, 2011 I want this car. :) Looking good Mike. Quote Link to comment
DISLEXICDIME Posted January 2, 2011 Author Report Share Posted January 2, 2011 Somethig is wrong with this webber . I am not sure if it is the jetting or what . I drove it to mikes drive in last night . Man this thing is loud at low rpm's . The front struts are blown and the rear are not much better the rear brake lines need to be re done. But this thing sure seems to stick to the ground though . Quote Link to comment
banzai510(hainz) Posted January 2, 2011 Report Share Posted January 2, 2011 Somethig is wrong with this webber . I am not sure if it is the jetting or what just for info here if the head does not have water passages to heat the weber it could ice up at higher rpm.(since its been cold lately) if still points ignition look into this also first. Quote Link to comment
DISLEXICDIME Posted January 2, 2011 Author Report Share Posted January 2, 2011 Yah I am going to check the points today I wish my dwell meter didn't die on me. Quote Link to comment
DISLEXICDIME Posted January 3, 2011 Author Report Share Posted January 3, 2011 Any one want to take a pic of the Condensor inside of there single points distributor for me? I want to make sure the right size condensor is in my distributor. Quote Link to comment
sinner720st Posted January 3, 2011 Report Share Posted January 3, 2011 damn it... i should have gone last night. i did not know you got another car, i think you should do something else besides the sr20, only because you already have one. the car looks sick Quote Link to comment
DISLEXICDIME Posted January 3, 2011 Author Report Share Posted January 3, 2011 But this one has wide tires I can turn up the boost. How long you back for. Quote Link to comment
DISLEXICDIME Posted January 3, 2011 Author Report Share Posted January 3, 2011 After talking to jnec last night and getting some back ground on the car . I went out and pulled the carb apart cleaned all the jets checked there sizes it has 140 main 60 idle and a 170 air corrector on the main circuit. Nothing was clogged there was a verry small amount of crap in the float bowl . After I stuck it all back together I did the thing I always tell every one to do when they are having weber issues . Make sure the mounting bolts are tight! I tightened each bolt at least 1.5 turns. I am going to test drive it today. Wish me luck. Thanks jnec Quote Link to comment
Rustina 510 Posted January 3, 2011 Report Share Posted January 3, 2011 Hope it works dude, are we still on for this Friday for the parts I'm buying from you Quote Link to comment
DISLEXICDIME Posted January 3, 2011 Author Report Share Posted January 3, 2011 Yah Quote Link to comment
Rustina 510 Posted January 3, 2011 Report Share Posted January 3, 2011 Cool, I have Friday off work too!! It will be nice to meet you finally. C U Friday dude. How did the car run? I have a couple nice intake manifolds that will fit you weber if you want them. Quote Link to comment
DISLEXICDIME Posted January 3, 2011 Author Report Share Posted January 3, 2011 Didn't drive it yet I spent the day rc crawling. Quote Link to comment
banzai510(hainz) Posted January 4, 2011 Report Share Posted January 4, 2011 If YOu have a L20 b distributot he condensor is inside the cap and is most likely the correct one. just make sure its grounded and screws are tite. condensore most like when bad soon as you rev it up the starts popping/cutting out ect... justr absorbs the ac current or arching across the points. PS you should have a ballast resisitor with a point ohm coil of around 1.2 to 1.8 ohm should be OK. If you have a ballast and put on a MSD or a later EI 200sx coil it could be to much for the points. Im guessing and IM not there to hear it. But webers are EZ to swap out just to ck this also. a overtite hex nut on back of a weber can cause a off idle bog also. anytime I ck a L motor I ck the cam timming and dizzy shaft timming. and do a valve lash adj. If all good then look at carb or ignition. Oh one last Hail Mary! make sure the vac adv is tite dizzy shaft wobble vac adv is hooked up to carb and not the intake manifold Quote Link to comment
DISLEXICDIME Posted January 4, 2011 Author Report Share Posted January 4, 2011 Good advice what do you run your single point point gap at hainz? I just set mine to 17 they where not opening verry much Quote Link to comment
sinner720st Posted January 4, 2011 Report Share Posted January 4, 2011 But this one has wide tires I can turn up the boost. How long you back for. not sure when im goin back to hawaii. but i should be around this weekend. i think a beav meet needs to crappen, and get the box dime runnin so i can see it!!! Quote Link to comment
