Fuse box
Z-train
  • Replies 4
I dont remember off the top of my head the difference between the earlier and later fuse boxes, I think this cover is off of a 74.
On the left side from top to bottom
15 Amp, head lamp
15 Amp wiper/washer/heater
10 Amp Meter/Reverse/Regulator
The wiper/washer and the meter/reverse/regulator are the only two pn the whole fusebox that are hot when keyed. The headlights are obviously hot from the batt/alt.
On the right side, from top to bottom
10 Amp, Park/tail
15 Amp, radio/Cig lighter/room
15 Amp, Horn/Stop/Hazard
All the fuses on this side are hot from the batt/alt.
I think there was a difference in the later ones, IM pretty sure that the fuse values stayed the same but I think that there was something else running off of one of the keyed hot.
Hopefully this helps, I posted up the differences in both somewhere on here a while back but Ill be damned if I can find it now.
Soak your fusebox in vinegar or lemon juice and make sure all the tabs holding the fuses in are tight... Dirty/ loose fuses seems to be such a common problem that this is the first thing I do before I even start trouble shooting. Also make sure you have the correct amp fuse after you get it all cleaned up.
15 Amp, head lamp
10 Amp, Park/tail
The HL fuse I thought was top right? And the later ones swapped the hl fuse to keyed hot. I have a later box in my 73.
