datzenmike Posted January 21, 2008 Report Share Posted January 21, 2008 The following is for the 5 spd L series bolt pattern only. Does it have a dogleg or regular 5spd pattern? The dogleg tends also to have a smooth bell and the regular shift has ribs cast into it. Is it long tail (about 31" total length) or short tail (about 26" total length)? Is 5th gear an o/d (over drive) or DD (direct drive) straight through? Does it have a spline or bolt on flange output? 'A' type rubber mount (Monkey Motion) If it has this shifter, it could be from a roadster, early 240Z car (rare non US spec.) 'B' type cross pin mount If it has this shifter, it could be from a '77-'79 620 truck, '80 720 truck, '78-80 or '80-'83 280z or 280zx car, Nismo wide ratio o/d fifth gear, Nismo close ratio o/d fifth gear (also used on the 260Z 2+2 non US spec.), or one of three Nismo DD (direct drive) fifth gear trannys. 'C' type top cover mount held by circlip, also known as a top loader Borg Warner T-5 for the 280zx, Nismo ultra close ratio o/d fifth gear or Nismo middle ratio o/d fifth gear tranny. The tranny on the far right is a T-5 (C type) for comparison to a FS5W71B (B type) long tail 5spd on the left. 280Z and 280ZX 5spd I.D. Here is a dogleg 5 spd. Note the smooth case. This is a long tail believed to be from an 810/Maxima which is built on the 280Z platform. Note the 280z type tranny mount and B type shifter. Another dogleg 5spd, a short tail with B type shifter, believed to be from a '78 510. Speedo appears to be on driver's side. http://i138.photobucket.com/albums/q251/datzenmike/transmissionDoglegshort78510.jpg[/img]"] Here's two with bolt on output flanges, a Nismo competition box with B type shifter (left) and an early FS5C71A close ratio Roadster box with A type shifter and detachable bell housing. Also known as the Nismo ultra close ratio: 1st - 1.858 2nd - 1.383 3rd - 1.217 4th - 1.000 5th - 0.850 http://i138.photobucket.com/albums/q251/datzenmike/Transmissioncloseratiocompititionbo.jpg[/img]"]http://i138.photobucket.com/albums/q251/datzenmike/transmissionearlycloseratioroadster.jpg[/img]"] This may narrow it down some. Ratios can be only guessed at as the original tranny may have been swapped out of the car and there were even changes without notice at the factory. Add to this an optional tranny may have been ordered when new. Every effort has been made to maintain accuracy. This is by no means a complete list. I welcome any additions or adjustments. Quote Link to comment
datsunaholic Posted January 21, 2008 Report Share Posted January 21, 2008 Mike, Doglegs don't have the "Monkey motion" shifter- their shifter looks exactly like a 71B type. I've never seen a 71B 5-speed with the top access plate- only 4-speeds. I've had several 1977 71B 5-speeds (both from trucks and Zs), which were the 1st year, and all had the single ridge and the single ear. The only difference I saw between early and late was the shifter itself (the later ones had a plastic spring-loaded spacer). I'm not saying that such doesn't exist- I mean, I didn't know that longtail doglegs or longtail bottom-cover 4-speeds existed either (both of those oddballs were confined to models I've never owned). Quote Link to comment
datzenmike Posted January 21, 2008 Author Report Share Posted January 21, 2008 Adjustment made. I understand the earliest 5spd was only a four with a 5th tacked on. It shared the weak reverse shifter rod and were notorious for breaking and loosing both gears. Quote Link to comment
datsunaholic Posted January 21, 2008 Report Share Posted January 21, 2008 The earliest 5-speed was the roadster one, which I haven't gotten a real good look at. It has a 3-piece case (the bellhousing is completely separate unlike the later ones) and were the same unit that were used in the early 240Z as a dealer add-on. Quote Link to comment
datzenmike Posted January 21, 2008 Author Report Share Posted January 21, 2008 Three piece, like the last picture, the one in the crate. I meant the early '77 280 Z tranny. (shouldn't have said earliest) Quote Link to comment
sdsurf Posted January 22, 2008 Report Share Posted January 22, 2008 Ok, My truck (521) is set up with a 4spd out of a 77' 620. It has the b-type shifter and the access cover. The drive shaft has already been shortened to accomodate it. What 5spd is the direct swap? Just want to be clear on all of my options Mike Quote Link to comment
datsunaholic Posted January 22, 2008 Report Share Posted January 22, 2008 If you have the '77 620 4-speed, then a '77-78 truck (2WD) 5-speed is a direct swap, the '79-80 truck 5-speed just needs the speedometer drive changed, and a '77-83 Z/ZX (non-turbo) swaps, also with a speedometer drive swap (generally, use the one from the '77 4-speed) Quote Link to comment
bonvo Posted March 7, 2008 Report Share Posted March 7, 2008 i have a dogleg out of a 77 200sx and i was wondering if the 5th gear is an od or 1:1 Quote Link to comment
phatdave Posted March 7, 2008 Report Share Posted March 7, 2008 All 5 speeds are overdrive Quote Link to comment
bonvo Posted March 7, 2008 Report Share Posted March 7, 2008 thats what i thought but then i read on here that there is a tranny that the 5the is a 1:1 so i wanted to be sure what i was putting in was what i wanted not my 4 speed with an extra shift Quote Link to comment
datzenmike Posted March 8, 2008 Author Report Share Posted March 8, 2008 No they aren't. Some are 1 to 1 in 5th gear and are called an F5C71B direct drive. The S in FS5W71B denotes an over drive 5th gear. I would doubt very much that there are many floating around out there. I believe these would be a specially ordered Nismo option for racing and such. There's even one for the 620: 1st....2nd...3rd..4th...5th 3.321 2.27 1.60 1.24 1 Quote Link to comment
ppeters914 Posted March 9, 2008 Report Share Posted March 9, 2008 DatzenMike, what's up with the pics in your original post? Only one of 'em displays anymore. :confused: Quote Link to comment
datzenmike Posted March 9, 2008 Author Report Share Posted March 9, 2008 I musta been bad or something. Some of my later ( few days ago) pix are gone too. Is there a limit to how many pictures I can post????? Maybe I could delete some of the really old ones.?? Thomas? Quote Link to comment
Doctoraudio Posted April 13, 2011 Report Share Posted April 13, 2011 Hello guys looking for some answers. The tranny , I picked up. Says it has monkey motion shifter linkage. What the hell is that? Also says it is rare. The tranny is just a little over 31 inches long. Here is a picture of it, after I cleaned it up. I am just trying to get as much info as possible before I drop my 4 speed and put this one in my 510 wagon. I am going to have a sedan driveline cut 3 inches shorter. Then put it all in. The sedan drive line is 2 inches shorter than the one that is on the wagon now. Does this all sound right to you? Thanks a head of time. Quote Link to comment
datsunaholic Posted April 13, 2011 Report Share Posted April 13, 2011 That's not the monkey-motion type. Looks like a immensely common FS5W71B transmission to me. What it came out of, Mike seems to be the Amazing Kreskin of tranny ID (something to do with the placement of the switches and such). It looks like a '77-79 280Z or 77-80 Truck trans to me. It has a truck-type slave cylinder on it. Quote Link to comment
datzenmike Posted April 13, 2011 Author Report Share Posted April 13, 2011 FS5W71B 5 speed for L series motor made for the U.S. '79 620 truck (non California). Possibly the '80 2wd 720 truck. (non California) Not any newer than Dec.'80 not older than July '78. It was assembled by a left handed Asian male.. It has a truck-type slave cylinder on it. lolz just saw your post Doug. I looked at the slave but didn't 'see' it. Yes definitely a truck slave, good call. Further, either year gear ratios are.... 1st... 3.592 2nd.. 2.246 3rd... 1.415 4th... 1.000 5th... 0.882 rev... 3.657 These are a relatively 'wide ratio' gear set suitable for a truck with a very low first gear and large spread between all gears. Quote Link to comment
datsunaholic Posted April 13, 2011 Report Share Posted April 13, 2011 The Amazing Kreskin makes his appearance. The limiting it to a '79 (or 80) Non-Cali Truck Trans must be because of the 3 (rather than the more common 2) switches, right? Quote Link to comment
datzenmike Posted April 14, 2011 Author Report Share Posted April 14, 2011 The only other 5speed (280z/zx and Maxima) uses only the reverse light switch. California 620/720 use a neutral switch in the upper tailstock so they are out also. The 620 received top and overdrive gear switches (likely for the fuel shut off system on deceleration) in '79 and used well into the '80s. To the best of my knowledge and research material and skills this is the best guess. As always it's possible there were undocumented changes by Nissan over 30 years ago. Quote Link to comment
Sealik Posted April 14, 2011 Report Share Posted April 14, 2011 FS5W71B 5 speed for L series motor made for the U.S. '79 620 truck (non California). Possibly the '80 2wd 720 truck. (non California) Not any newer than Dec.'80 not older than July '78. It was assembled by a left handed Asian male.. Here's my recently acquired '80 720 2WD trannie for comparison Quote Link to comment
datzenmike Posted April 14, 2011 Author Report Share Posted April 14, 2011 FS5W71B 5 speed for L series motor made for the U.S. '79 620 truck (non California). Possibly the '80 2wd 720 truck. (non California) Not any newer than Dec.'80 not older than July '78. It was assembled by a left handed Asian male.. Yup.....that's the Canadian one. :lol: Quote Link to comment
Doctoraudio Posted April 14, 2011 Report Share Posted April 14, 2011 Thanks for the info guys. I went back and searched thru the add on craigslist. It said, it came from either a 240Z or a Roadster. So, could it be one? What happen to you photo bucket oics? Quote Link to comment
datsunaholic Posted April 14, 2011 Report Share Posted April 14, 2011 No. There is no way it's that early of a transmission. Roadster transmissions 1) have the starter on the other side and 2) have 3-part cases. 240Z 5-speeds were Roadster 5-speeds with L-series bells on them... again, 3-piece cases. Now, it COULD have been swapped into a 240Z in the 80s or 90s, but that's not where it came from. Mike says it's a 79-80 Truck Trans, and I have no doubt that's what it is. Quote Link to comment
Doctoraudio Posted April 14, 2011 Report Share Posted April 14, 2011 Okay guys, Thanks. Knowing is half the battle. Quote Link to comment
KoHeartsGPA Posted March 9, 2016 Report Share Posted March 9, 2016 T T T Mike can you please update the pics on your initial post? Thanks! Quote Link to comment
KoHeartsGPA Posted March 9, 2016 Report Share Posted March 9, 2016 And maybe pin it since its very good info :thumbup: Quote Link to comment
