DatDoug Posted November 26, 2010 Report Share Posted November 26, 2010 Threw the studs on the truck the other day so I could get around in the snow. Drives pretty good for a 1 tire fire low rider :P Thot it looked cool with the icecicles hangin down. Looks like whiskers in the front :D Quote Link to comment
wildmaninid Posted November 26, 2010 Report Share Posted November 26, 2010 Can't bead studs and some weight in a 620. throw a pair of tire chains in behond the seat and you will pass all the 4x4's in the ditch no matter how bad the roads get! Quote Link to comment
Ken_B Posted November 26, 2010 Report Share Posted November 26, 2010 You are braver than I, my 521 hasnt left the garage for a week. Fuelin my F150 is killin me. Cant wait till the roads clear up. Quote Link to comment
datzenmike Posted November 26, 2010 Report Share Posted November 26, 2010 I had a 521 in the late '70s and I agree. They will go unbelievable places with snow tires. I had 225s all round and cranked the front up and used to go down ski-doo trails. The snow was hard packed and the truck was light. Chevs and Fords couldn't follow me. Even went through fields with over a foot of snow. Only down side was the shitty heater on them. Quote Link to comment
herculesinwyoming Posted November 27, 2010 Report Share Posted November 27, 2010 I had a 521 in the late '70s and I agree. They will go unbelievable places with snow tires. I had 225s all round and cranked the front up and used to go down ski-doo trails. The snow was hard packed and the truck was light. Chevs and Fords couldn't follow me. Even went through fields with over a foot of snow. Only down side was the shitty heater on them. That sounds a little hard to believe, unless they were 2x2 fords and chevys Quote Link to comment
Sealik Posted November 27, 2010 Report Share Posted November 27, 2010 My first Nissan was a 85 2 WD ST with Blizzaks. Could pretty much go anywhere until it bottomed out in snow. Had to upgrade to the 4WD.. :thumbup: ...no comparison. Quote Link to comment
Gary Posted November 27, 2010 Report Share Posted November 27, 2010 heh that does look awesome :D nice pics Quote Link to comment
polski ogorki Posted November 27, 2010 Report Share Posted November 27, 2010 Only down side was the shitty heater on them. I agree Mike /\ . I need to switch over to my winter thermostat asap! DatDoug your truck looks sweet! I'm running studded arctic claws and they kick ass! I drive the snowy highway everyday and everyday there has been someone in the ditch.But not the 620! (Knocking on wood now) Rich Quote Link to comment
datzenmike Posted November 27, 2010 Report Share Posted November 27, 2010 That sounds a little hard to believe, unless they were 2x2 fords and chevys Not really they were 2-3 times heavier than me and would break through the crust. Plus idiots. Quote Link to comment
moparvwfreak Posted November 28, 2010 Report Share Posted November 28, 2010 i was scared to drive my 620 in the snow. i took the wifes jeep. it worked out pretty good. now i could always throw some black walnut in the bed and just mob... that might be fun! Quote Link to comment
Buzzbomb Posted December 6, 2010 Report Share Posted December 6, 2010 Do you guys run tube sand or anything in your beds? Last year I ran a 50# bag of tube sand directly on top of my rear axle, and honestly didn't see much of a difference than when running nothing back there. Just curious.. I am a big fan of a 195 degree thermostat now. The heater in my 720 works so good now I can drive around with just a t-shirt on in 10 degree weather! PLus I fixed the speeds on teh control thanks to Datzenmike :) ..Add in some cable "chains", and I would rather drive my truck in the snow and ice than any front wheel drive car I've ever tried driving in the winter :D It's actually kind of fun, but would be a whole lot funner without the Hummer = invincible crowd on the road.. Quote Link to comment
datzenmike Posted December 6, 2010 Report Share Posted December 6, 2010 Weight over the wheels helps them to dig in, in deep snow/mud but usually you need in the hundreds to notice anything. The drawback is changing direction or stopping on ice or poor traction. Each pound you add is another pound that increases forward inertia adding distance to a slide. Another is oversteer on corners or braking on poor traction. The heavier back end wants to 'come around' on you. Snow tires have experienced a revolution in design and grip like nothing before. You can also run lower tire pressure when cold. This increases traction at the expense of mileage. Running lower pressure causes them to flex the sidewalls more and this makes heat which over time will destroy a tire, usually suddenly. I say in the winter because it's colder and heating is less. Perhaps lower pressure to get out of a snow situation and then air up next chance. Never run severely low or low for long periods at high speeds. Quote Link to comment
kaoss Posted December 6, 2010 Report Share Posted December 6, 2010 50 lbs isn't going to do anything for you. Fill the entire bed with snow. Quote Link to comment
Suspect Posted December 7, 2010 Report Share Posted December 7, 2010 I usually drive one of my rustiest 620's in the winter time. They drive excellent, far better than my Chevy S-10 I had. I didn't add any weight, usually drive with Blizzak Snow Tires but last year, I drove my 73 with good condition normal tires and it did good. I was getting too daring one night, and I spun it out on some snow covered S corners at 50mph. I spun all the way around 1.5 times and went off the road backwards. I got out of my truck and looked at it. I thought I was going to have to get it towed out because the snow was as high as the top of the bed. All it took was a couple rocks and I was going down the road again. There was a foot of snow in the road and 2 to 3 feet of snow off the road. This year I'm not driving a datsun for the winter. I figured I'd switch it up and drive my 63 Mercury. Quote Link to comment
Z-train Posted December 7, 2010 Report Share Posted December 7, 2010 Put one of these in your truck bed.Should be enough weight. Quote Link to comment
GOLSETH Posted December 21, 2010 Report Share Posted December 21, 2010 WOW! I really like what youve done to your 620!!! What wheel/tire size are you running! Looks great! Quote Link to comment
DatDoug Posted December 22, 2010 Author Report Share Posted December 22, 2010 WOW! I really like what youve done to your 620!!! What wheel/tire size are you running! Looks great! Those are 15" Pathfinder/4x4 truck wheels with 195-60's Quote Link to comment
Nissan_Boy85 Posted December 22, 2010 Report Share Posted December 22, 2010 Sweet pics. Reminds me when I was running my 720 in the show a few years ago when we got the near foot. It had Hankook K-106 street tires on it and it would go anywhere I asked it until the front valance became a snowplow. Quote Link to comment
GOLSETH Posted December 27, 2010 Report Share Posted December 27, 2010 Cool... Do you know what offset your wheels are? Quote Link to comment
mike Posted December 27, 2010 Report Share Posted December 27, 2010 Ha ha, Im letting my little sister drive the blue 620. It does pretty good in the snow, I was going to raise it back up but there was no need. About 150 to 200 lbs over the axle does it just right with some studs. Quote Link to comment
elmerfudpucker Posted December 27, 2010 Report Share Posted December 27, 2010 Z-Train... please dont post that again.... I think I am gonna hurl :sick: :D I havent got to try out the new tires yet on the 720...no snow or ice.... :( Quote Link to comment
