68Datsun510 Posted November 25, 2010 Report Share Posted November 25, 2010 So im basically on a mission to run as many older cars as possible. The dash in my hardbody pickups going all disco on me, CEL is on, ABS is on, too much electronic shit! I have my 4.3L 4x4 blazer as my 'new' car so i dont really even need my HB anymore. Just another cotsly smog appointment. Anyay, 521 Pickups. The one im looking at is a 1969. How easy to swap a 5 speed into? Whats the rear end ratio? If it has a J series, how hard to swap to L? Is J reliable? Load capacity? I dont know too much about them, except that I love the styling, and I want to get one! Would be a perfect match for my Gumby Green 69 510! Quote Link to comment
wayno Posted November 25, 2010 Report Share Posted November 25, 2010 Hi there 68datsun510, I think in 69 they came with the J13 engine, there is room in there for a L block, but you have to fabricate engine mounts, the J block radiator sheet metal can be cut out for the L block radiator to fit, it has the L block holes for the radiator already there. There are two ways to put a 5 spd. behind a L block, the easy way is to buy a 200SX dogleg 5 spd. that will need some modifacation to the tranny mount, and a longer driveline will need to be fabricated. the other way is more complicated and involves a napZ 5 spd. which I will explain to you if you get that far. I don't beleave there is a easy/inexpencive way to get a 5 spd. for a J block. I beleave that the rearend has 488 gearing, I could be wrong, but you could put 437s in it fairly easily. Most of the datsun trucks were rated for one ton in that era, they will haul that much, but they have drum brakes all around. wayno Quote Link to comment
68Datsun510 Posted November 25, 2010 Author Report Share Posted November 25, 2010 Interesting. RockAuto.com lists BOTH engines as available, but who knows whats 'real'. Thanks for the info Wayno, very helpful. Drum brakes dont scare me really, they do work, as long as you dont try and stop 2000lbs in under 100ft lol. Quote Link to comment
Pacific coast Datsun Posted November 26, 2010 Report Share Posted November 26, 2010 Id search for a 70 71 or 72. Reason being they already have the L motor & swapping in a 5 speed is more common. I put a 5 speed out of a 83 280ZX in my 71 521. Totally do-able yourself with a few basic tools. I had to...shorten the driveshaft, shorten/modify the trans. mount & modify the yoke on the front of the driveshaft. I did a writeup w/ pix if ya need em. Quote Link to comment
68Datsun510 Posted November 26, 2010 Author Report Share Posted November 26, 2010 This 69 apparently is a late model, it has the L16 already. We shall see, im going to tracy this weekend and stopping by in Galt to check it out. Its on CL. Quote Link to comment
Pacific coast Datsun Posted November 26, 2010 Report Share Posted November 26, 2010 If it's got the L i say go for it :D Quote Link to comment
Jayden71 Posted November 28, 2010 Report Share Posted November 28, 2010 If it has L16 then rearend ratio will be 4.375. With a 4 speed 60mph will be bout 3900rpm. You could do almost 70 at same rpm with 5 speed :D Long live the 521!!!! Quote Link to comment
68Datsun510 Posted November 29, 2010 Author Report Share Posted November 29, 2010 Long live the 521!!!! Haha, couldnt agree more! I never did end up going to see that 521. I need to control my impulses on projects. Im stuck in the middle of an engine rebuilt, heater recored, and an interior update on my 510, and there is a possible 1970 barn find 240Z in my future... I will stick with the HB truck for the time being... :P Quote Link to comment
Ken_B Posted November 29, 2010 Report Share Posted November 29, 2010 I love my 521 and drive it every day, I will say though that the brakes, stock seat, and heater leave a little to be desired. Quote Link to comment
wayno Posted November 29, 2010 Report Share Posted November 29, 2010 I love my 521 and drive it every day, I will say though that the brakes, stock seat, and heater leave a little to be desired. That's what upgrades are for, you get to work on your datsun and make it better. :lol: Quote Link to comment
Ken_B Posted November 30, 2010 Report Share Posted November 30, 2010 That's what upgrades are for, you get to work on your datsun and make it better. :lol: Yeah for sure, once the funds allow it, it will be getting front disc brakes and by then it'll be warm out again and I'll stop whining about the heater :D Quote Link to comment
