machowgn Posted January 18, 2008 Report Share Posted January 18, 2008 Hello, I have a 72 521 pickup truck,L-16. I just won off of e-bay a rare 5-speed tranny from portugal that was in a sss bluebird. I was told by the owner that it was mated to an L-16 when pulled, It's the close ratio 5-speed. I thought it would be a great upgrade for my truck. But I'm wondering if there is a way to determine if I have the correct bellhousing to use with my trucks set-up? Does anyone know if it will directly bolt up, or will I need a different bellhousing? I know Datsun made several different types? Thanks in advance, Mike here in California. Quote Link to comment
Pacific coast Datsun Posted January 18, 2008 Report Share Posted January 18, 2008 If the trans. was bolted to a L motor it will bolt up. Use the truck throw out bearing & clutch slave cyl. I did a Z 5 speed swap in my 71 521 & di da writeup w/ pics...... http://forum.ratsun.net/showthread.php?t=523 Youll prob. have to shorten the front section of the driveshaft & cut the tunnel back a bit to accept the new shifter location. Quote Link to comment
banzai510(hainz) Posted January 18, 2008 Report Share Posted January 18, 2008 a rare 5-speed tranny from portugal ? i bet its not that rare The shipping will be outragous and coud have gotten a 5 speed here in the US Quote Link to comment
datsunaholic Posted January 18, 2008 Report Share Posted January 18, 2008 Not that rare- probably from a late 70s 160B SSS (basically either a Euro 610 or more likely a 4-cyl version of the 810), though non-OD 5-speeds were available then (the TRUE close-ratio), which aren't any help on a street vehicle since its top gear is 1:1 just like a 4-speed (except you have to shift more to get there). Or, it could just be a longtail dogleg. Quote Link to comment
