primo74620 Posted November 9, 2010 Report Share Posted November 9, 2010 How about a "How To" on how to fix the window crank that is stripped. Quote Link to comment
Braden Posted November 9, 2010 Report Share Posted November 9, 2010 How to fix Stripped Windo Crank. Go to Junkyard and find An unstripped crank and regulator assebly for a 510, come home, remove door panel, remove old assebly, install new used Assebly, put on door panle, put on crank, enjoy feeling the breeze!!! of just jb weld your crank onto your stripped one. 1 Quote Link to comment
Laecaon Posted November 9, 2010 Report Share Posted November 9, 2010 Does the clip still clip on? what is actually stripped? The arm that detaches and is plastic or the splined piece that you turn to make the window go up and down, it is metal. Anyways I would drill a hole through the metal splined piece, and then use a screw to go threw the metal piece. It would attach to the arm. Since the arm is plastic remember to drill some relief holes so it doesnt split. This is what I mean. Quote Link to comment
primo74620 Posted November 9, 2010 Author Report Share Posted November 9, 2010 Does the clip still clip on? what is actually stripped? The arm that detaches and is plastic or the splined piece that you turn to make the window go up and down, it is metal. Anyways I would drill a hole through the metal splined piece, and then use a screw to go threw the metal piece. It would attach to the arm. Since the arm is plastic remember to drill some relief holes so it doesnt split. This is what I mean. The splined metal piece the attatches to the regulator is what is stripped. I know I could go to the jy and get a good one. I was looking for a quick fix for mean while. Quote Link to comment
metalmonkey47 Posted November 9, 2010 Report Share Posted November 9, 2010 The splined metal piece the attatches to the regulator is what is stripped. I know I could go to the jy and get a good one. I was looking for a quick fix for mean while. I used permatex once. lol A ratsun fix for sure. It allowed me to remove it and put on a new one after I got another. Quote Link to comment
MikeRL411 Posted November 10, 2010 Report Share Posted November 10, 2010 Quick and dirty, might even work for a while - use a piece of shrink fit tubing on the door spline and force the crank over it. Might have to heat the tubing so it will not slip off. Good luck! Quote Link to comment
hang_510 Posted November 10, 2010 Report Share Posted November 10, 2010 How about a "How To" on how to fix the window crank that is stripped. excellent plan! when are you going to post it??? replacing the regulator is pretty straight forward... R&R Quote Link to comment
