]2eDeYe Posted November 22, 2011 Report Share Posted November 22, 2011 Looks great :cool: Quote Link to comment
VintageRice Posted January 10, 2012 Author Report Share Posted January 10, 2012 Picked up some more Ka swap items. Got a trans, clutch set, starter and shifter all from the same guy. Looking for a flywheel now and waiting for my head to get rebuilt. Also still need to buy a cam (O&J) and do the timing set and put the motor together. Anyone looking for a running L18 and 4 speed ??? After a quick bath. Quote Link to comment
VintageRice Posted January 10, 2012 Author Report Share Posted January 10, 2012 Just realized I hadnt put any pics up of my motor. Found out that the valves had tapped the pistons. Carbs Quote Link to comment
philcas1987 Posted January 10, 2012 Report Share Posted January 10, 2012 make sure you get a good timing set. Napa is the only place I've found to have a good set. Expensive though. The timing chain tension guide is one piece as opposed to the cheap China stamped two piece one. The fail right were it bolts to the block. It gets loose right were it wraps around. Quote Link to comment
VintageRice Posted January 10, 2012 Author Report Share Posted January 10, 2012 Napa, will do! Quote Link to comment
Z chopper Posted January 13, 2012 Report Share Posted January 13, 2012 R1 carbs sweet Quote Link to comment
VintageRice Posted February 9, 2012 Author Report Share Posted February 9, 2012 Havent done much lately, only went for a short drive in the sun. Snapped a few shots. Quote Link to comment
]2eDeYe Posted February 9, 2012 Report Share Posted February 9, 2012 Great pics! :cool: Quote Link to comment
VintageRice Posted February 19, 2012 Author Report Share Posted February 19, 2012 Did this today with the boys. KA here we come! Quote Link to comment
VintageRice Posted February 19, 2012 Author Report Share Posted February 19, 2012 TimeLapse <iframe width="560" height="315" src="http://www.youtube.com/embed/0citLMEisdg" frameborder="0" allowfullscreen></iframe> Quote Link to comment
VintageRice Posted February 19, 2012 Author Report Share Posted February 19, 2012 TimeLapse <iframe width="560" height="315" src="http://www.youtube.com/embed/0citLMEisdg" frameborder="0" allowfullscreen></iframe> http://www.youtube.com/watch?v=0citLMEisdg&feature=youtu.be Quote Link to comment
Alex Datsun Posted February 19, 2012 Report Share Posted February 19, 2012 Gotye!! I dont remem if i spelled thag right. Nice work though seemed pretty straight forward. Quote Link to comment
mrbigtanker Posted February 19, 2012 Report Share Posted February 19, 2012 Wow only 1.45 to pull that motor and trans you guys are fast.and you guys walk fast to.slow down.haha Quote Link to comment
VintageRice Posted March 5, 2012 Author Report Share Posted March 5, 2012 Flipped my crossmember today. Heres Oics Before After Joby Cleaned it up first Welded a Bar on for a jig but ended up bolting the ends back into the car and welding the center back in just to make SURE it was right. Then we took it out and finished welding. Gangster Joby \ Quote Link to comment
fisch Posted March 5, 2012 Report Share Posted March 5, 2012 Nicely done sir! (pretty weld there too!) Quote Link to comment
VintageRice Posted March 11, 2012 Author Report Share Posted March 11, 2012 Put my KA together today!!! Andrew and Joby came to help! Was GREAT! One step closer. Honing Crank Bearings Rings Scary Andrew Piston time! Delicious! Tappy Tappy, tap tap a lappy What the He!! did you do with the.........oh here it is. The Aftermath Important stuff done......more to come Quote Link to comment
VintageRice Posted March 14, 2012 Author Report Share Posted March 14, 2012 Got more done today. Got motor the rest of the way buttoned up, got my matchbox dizzy munted. Por-15'd both the trunk and the engine bay. Also seam sealed the trunk. Should be dropping the motor in soon !! Quote Link to comment
VintageRice Posted March 23, 2012 Author Report Share Posted March 23, 2012 Motors in!! Quote Link to comment
el'grande Posted March 23, 2012 Report Share Posted March 23, 2012 subscribed! Im new to the forum and was shooting to start this same swap in a month or so, and am excited to see how yours goes. Looks great so far. Quote Link to comment
MYTE_510 Posted March 23, 2012 Report Share Posted March 23, 2012 What did you use for motor mounts? I thought I had 240 mounts on my last KA until I just picked up my new KA that came from a 240 and they were totally different.... So now I'm looking for a type of motor mount to use. The old ones were shot btw. Quote Link to comment
VintageRice Posted March 23, 2012 Author Report Share Posted March 23, 2012 Stock Ka (240sx) top mounts. Stock 510 lower rubber mounts. But, you have to unbolt the lower mounts and move them down using the other set of holes in the mount plate. EZ. Quote Link to comment
MYTE_510 Posted March 23, 2012 Report Share Posted March 23, 2012 Thanks. Ill have to double check my setup..... Quote Link to comment
Draker Posted September 3, 2012 Report Share Posted September 3, 2012 Details in flywheel? Where did you get it? Quote Link to comment
VintageRice Posted September 3, 2012 Author Report Share Posted September 3, 2012 ebay Been great so far. Fitment seemed high quality. I've read good things too before purchase. you cant beat the price. $154 ! ! ! And I weighed it when it got here and it is 11.5 LB's Great deal. http://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l2736&_nkw=F1+RACING+LIGHTWEIGHT+PROLITE+CHROMOLY+FLYWHEEL+89-98 Quote Link to comment
VintageRice Posted September 3, 2012 Author Report Share Posted September 3, 2012 Quote Link to comment
