epfrz Posted November 8, 2010 Report Share Posted November 8, 2010 I have a water leak in the cab of my 76 620, its coming out on the drivers side around under the speaker area. Any thoughts? (Water leak is not good in Washington!) Quote Link to comment
moparvwfreak Posted November 8, 2010 Report Share Posted November 8, 2010 dont feel bad, mine leaks behind the seat at the seam where the back of the cab and the floor meet. Quote Link to comment
dat620 Posted November 8, 2010 Report Share Posted November 8, 2010 take the wiper cowl off and ck for rust holes, drilled holes, also ck the fire wall area on that side for open holes, and or how is the wind shield gasket, if cracked or dryed out and shrinking it to can leak in that area, had it happen on the passenger side of mine, got a new gasket all good..ck them out.. Quote Link to comment
DatDoug Posted November 8, 2010 Report Share Posted November 8, 2010 Welcome to the club. EVERY 620 ive had has leaked. & thats quite a few :blink: Quote Link to comment
PtheDude Posted November 9, 2010 Report Share Posted November 9, 2010 6x4' tarp and a few bungies keeps ol red dry, but she's not my daily driver... Quote Link to comment
Z-train Posted November 9, 2010 Report Share Posted November 9, 2010 How old is the windscreen gasket ? Quote Link to comment
datzenmike Posted November 9, 2010 Report Share Posted November 9, 2010 Take the wiper arms off and the cowl cover so you can access the wiper linkage area. On each side is a drain hole to let trapped water out just forward of each door and just to the rear of the front wheel well up under the fender. These ALWAYS get plugged with rotting leaves, maple leaf keys and pine needles. Water can back up and and leak in the rusty seams. Have someone hose the truck while you look inside with a flashlight. It's very possible the water is getting in at the top of the windshield but it runs down inside the rubber and along the bottom before dribbling out, so where you see it, may not be where it's actually leaking. Quote Link to comment
epfrz Posted November 10, 2010 Author Report Share Posted November 10, 2010 I did clean out the cowling, I think it may be the windshield gasket, its pretty hammered. Quote Link to comment
bbqbill Posted January 4, 2011 Report Share Posted January 4, 2011 I have a water leak in the cab of my 76 620, its coming out on the drivers side around under the speaker area. Any thoughts? (Water leak is not good in Washington!) check the seam on the a piller for cracks in the sealent Quote Link to comment
Llittle_Llama Posted January 12, 2011 Report Share Posted January 12, 2011 If you can't replace it right away silicone is ugly as hell, but does the trick. Quote Link to comment
izzo Posted January 12, 2011 Report Share Posted January 12, 2011 If you can't replace it right away silicone is ugly as hell, but does the trick. Thats the worst thing you can use, you should be kicked in the nuts for that. Dont, DONT use silicone.. Dont be a cheap ass, go and get some of that black goop shit they use on windshield installs & use it. I got a friend over in Puyallup that works for safelite, he might do it for a few bucks... Quote Link to comment
datzenmike Posted January 12, 2011 Report Share Posted January 12, 2011 Urethane sealer. Sticks like shit to your fingers but when dry looks just like rubber. Use black. Silicone won't stand up to UV rays. Quote Link to comment
Llittle_Llama Posted January 12, 2011 Report Share Posted January 12, 2011 Thats the worst thing you can use, you should be kicked in the nuts for that. Dont, DONT use silicone.. Dont be a cheap ass, go and get some of that black goop shit they use on windshield installs & use it. I got a friend over in Puyallup that works for safelite, he might do it for a few bucks... I only recommend the silicone if your replacing the weatherstripping. I didn't say it was a permanent fix, I was just saying it would work for a few days. My wifes escort leaked at the top of the windshield and I was on my 2 week national guard thing. She called, I had her do that, I got home a week later and pulled it off in one strip. Quarter tube of weatherstripping adhesive and it was perfect. Just make sure you wear some tight latex gloves if you're smoothing it out with your finger, like datzenmike said, it's sticky as shit. Get it on your hands and your wearing it off. Quote Link to comment
izzo Posted January 12, 2011 Report Share Posted January 12, 2011 I only recommend the silicone if your replacing the weatherstripping. I didn't say it was a permanent fix, I was just saying it would work for a few days. My wifes escort leaked at the top of the windshield and I was on my 2 week national guard thing. She called, I had her do that, I got home a week later and pulled it off in one strip. Quarter tube of weatherstripping adhesive and it was perfect. Just make sure you wear some tight latex gloves if you're smoothing it out with your finger, like datzenmike said, it's sticky as shit. Get it on your hands and your wearing it off. Dont listen to dumbshitter..... Dont use silicone... Quote Link to comment
Llittle_Llama Posted January 12, 2011 Report Share Posted January 12, 2011 Dont listen to dumbshitter..... Dont use silicone... Let me rephrase that, I meant I would only use it if I were replacing the weatherstripping, but not right away. If you are replacing it and just need a temporary fix for a week then you CAN use it. I only suggest it because it is cheap, easy to find, comes off easily, and everyone has it in there home. I am NOT saying this is a permanent fix. I am not saying this is as good as the weatherstripping adhesive, and I am not saying this is the best option. All I am saying is it works, it's cheap, and it's an option. The only reason I had my wife use it is I didn't want her using the adhesive and getting it on her and leaving bubbles, and I had full intentions of sanding down the area anyway before putting the adhesive in and it made no difference in the end. If you can fix it right the first time, do it. If you can't and this is your only means of fixing it for the time being, consider it... let me repeat that, CONSIDER it, not "this is the best option ever make sure to use tons!!!". Using an egg to plug a radiator is not a good idea, it will be all sorts of hell trying to get it all back out, but if you have no other options I guess that's what your going to do. Tell me so I know why you are so against it, what is wrong with the silicone for a few days? Give me a good reason besides "There are better ways" and I will never ever ever suggest it again. If I am wrong tell me so I can understand. If it's just a personal "I don't like that way" then just say so. Either way I would like to know. Also, the whole name calling is a little immature, a simple "I wouldn't do that if I were you" would suffice, grow up man. You saying don't do it with no reason behind it makes me think you just don't like it. If you had told me "don't do it because the windshield will fall out" I would make sure to tell people not to ever do it like you did. I know you have the stripping before as have I. I was telling him what I did, and you told him what you did. That's what forums are for last I checked. Quote Link to comment
