Dat620 77' Posted October 19, 2010 Report Share Posted October 19, 2010 On my 77 King Cab i just got done installing a l20b and a four speed tranny in it now i am wanting to fill the tranny with gear oil.But i got under it to do it and absolutly can not get the fill plug to break look it is stripped to all hell can i get some help here. what can i do to break it free so i can get gear oil i am so freaking frustrated u have no idea its freaking pissing me off guys HELP ME!!!!!!!!!!!! Quote Link to comment
ariascarlos1990 Posted October 19, 2010 Report Share Posted October 19, 2010 Use leverage to your advantage. Quote Link to comment
datzenmike Posted October 19, 2010 Report Share Posted October 19, 2010 Is it the outside square head or the inny that a 1/2" drive ratchet fits? Try to get as good a grip on it as you can and heat the aluminum around it with a small propane torch. Get it smokin' hot. Aluminum expands twice that of steel so the aluminum hole will get 'bigger' when heated. If using a 1/2" ratchet head slip a short length of pipe over the handle for more leverage.If it's the square head use vice grips. Quote Link to comment
Dat620 77' Posted October 19, 2010 Author Report Share Posted October 19, 2010 I have use leverage to my advantage and nothing it trys stripping more and this bolt is pretty well done for lol its killing me. I also dont have any way to get heat under there or i so would try it so what are my other options please help guys oh and thanks for the advice so far i will keep it in mind. Thanks Cody Quote Link to comment
