nnssr180sx Posted October 7, 2010 Report Share Posted October 7, 2010 I know this section is for write-ups only. But Ive looked on here and dont see anything for how to install a sr20det into a 510. I would think someone has already done this many times; could give a few pointers or two. A thorough instructions(w/pics) would be nice too. I know Mckinney Motorsports sells prefab parts sr20det 510 swap, such as manifold,downpipe,downpipe flange, crossmember, but are too expensive. If someone could layout what is necessary for purchase, and what can be worked around, that would also help. Maybe, with all the inputs this could be a useful writeup for this section. Thanks in advance. Quote Link to comment
INDY510 Posted October 8, 2010 Report Share Posted October 8, 2010 First of all....... you need ALL the wiring, ECU, and ALL the sensors........... even when you have that...... you may spend months just wiring depending on your skills Second: ...... do you have a welder?...... the front crossmember will need to be cut and flipped on a jig.. new motor mounts...... you need to shorten the driveshaft, custom transmission crossmember/mount,,,, new radiator,,, electric fans,,, KAs use 2 pressurized 5/16" fuel lines 1 return, 1 feed............ electric fuel pump... custom exaust header, or turbo manifold (with steering box clearance).....custom gas pedal w/ cable linkage......... cut/custom fit intercooler. ... all intercooler piping measured/bent and cut/welded ...... ... custom air intake pipe to MAF and new smaller air filter... ... or run a mega-squirt???..... better brakes?...... rack n pinion???....... Custom bent exaust........ and you need inlarge the exaust hole in the rear crossmember for any KA/SR ..... .. and maybe a better differential?? ... new bushings??.. brakes? if not rack and pinion: ...... the stock steering center link needs to be cut and flipped by a proffesional...... or buy a custom center link from MadDat in austrailia: http://www.maddat.com.au/1600.php Here are some helpfull links: How to wire a KA SR CA into anything: http://community.ratsun.net/topic/537-how-to-wire-a-ka-sr-ca-into-anything/ KA24DE info thread: http://community.ratsun.net/topic/746-ka24de-info/ Very well documented KA24 swap into a 510......... it took years.......... and probably over $6-7K http://dimequarterly.tierranet.com/tech/projectKA/projectKA.html Icehouse's SR20DET 68 2door: http://community.ratsun.net/topic/238-68-2-door-510-talk-about-rare/ Duke's carbed KA24DE build: http://community.ratsun.net/topic/4137-dukes-72-510/page__hl__%2Bduke%26%2339%3Bs+%2Bbuild Dillon's SR20DET build: http://community.ratsun.net/topic/3829-thrillen-dillons-dime/page__p__50474__hl__%2Bdillon%26%2339%3Bs+%2Bthrillen__fromsearch__1#entry50474 S15DET's 69 white 2 door: http://www.the510realm.com/viewtopic.php?f=27&t=5992&start=15 E510's SR20build....... he has all the fab skills you would ever want........ and swaps still aren't cheap: http://www.the510realm.com/viewtopic.php?f=3&t=14174&start=0 JermeyGass's SR20DET build: http://www.the510realm.com/viewtopic.php?f=3&t=13256&start=0 Goichi's SR20DET coupe: http://www.the510realm.com/viewtopic.php?f=27&t=8114&start=0 SSSR20DET's build: http://community.ratsun.net/topic/7894-69-510-sssr20det-project/ Cmac's SR20DET 2dr: http://www.the510realm.com/viewtopic.php?f=3&t=7118&start=0 Ash510's SR20DET build: http://www.the510realm.com/viewtopic.php?f=3&t=9098&start=0 Spriso's SR20DET coupe: http://www.the510realm.com/viewtopic.php?f=3&t=14871 Ecotech 510: http://www.the510realm.com/viewtopic.php?f=3&t=13582&start=0 Quote Link to comment
INDY510 Posted October 8, 2010 Report Share Posted October 8, 2010 2eDeYe' date='10 July 2010 - 10:19 AM' timestamp='1278782380' post='323750']This again? Recipe for a KA swap: Save up $2000 (what my swap cost, not including labor). This should get you a motor and all the parts needed, if your a bargain hunter. You'll also need some fab skill and a welder. Oh and you'll need some advance wiring skill also. Read up, research is key. KA24E in a 620 http://community.ratsun.net/topic/37-ka24e-into-a-620/ KA24DE in a 620 http://community.ratsun.net/topic/22191-1977-620-kingcab-deluxe/ Wiring for the motor. http://community.ratsun.net/topic/537-how-to-wire-a-ka-sr-ca-into-anything/ Wiring for the charging system. http://community.ratsun.net/topic/18218-how-to-install-a-saturn-alt/ After all that your gonna need some time, lot's of time and somewhere nice to work on it. The last thing you will need is a whole bunch of patience and perserverance. If you come back trying to sell your unfinished swap, I will ridicule and taunt you. :P Keeping a running motor in there is much easier. ;) Quote Link to comment
Skib Posted October 8, 2010 Report Share Posted October 8, 2010 I know this section is for write-ups only. so post it in the 510 or engines sub forums ......... please read Quote Link to comment
Laecaon Posted October 8, 2010 Report Share Posted October 8, 2010 you can buy a running KA510 for cheaper than swapping your 510 but that is no fun! 1 Quote Link to comment
nnssr180sx Posted October 8, 2010 Author Report Share Posted October 8, 2010 so post it in the 510 or engines sub forums ......... please read Sorry Skib- I was reading, just trying to encourage someone like indy510 to do a writeup for sr20det swap. Thanks guys! 1 Quote Link to comment
yello620 Posted October 8, 2010 Report Share Posted October 8, 2010 Was this thread started by Dwnshfter??? Quote Link to comment
Icehouse Posted October 8, 2010 Report Share Posted October 8, 2010 I actually would like to do a SR write-up. It would be really fun but I think since there are so many ways to go with it the write-up wouldn't really help that much. There are to many radiator/intercooler combo's. There are to many headers to clear steering box issues... There is no generic good way IMO. Quote Link to comment
Laecaon Posted October 8, 2010 Report Share Posted October 8, 2010 I think what most people want is mainly a checklist of things to do. And if an individual part is hard to find then a link to where it might be found. Specifics like what part from what car. I know I have seen everything needed by looking though numerous build threads, but I cant remember everything; one consolidated list would be great. 1 Quote Link to comment
nnssr180sx Posted October 9, 2010 Author Report Share Posted October 9, 2010 I actually would like to do a SR write-up. It would be really fun but I think since there are so many ways to go with it the write-up wouldn't really help that much. There are to many radiator/intercooler combo's. There are to many headers to clear steering box issues... There is no generic good way IMO. Icehouse, your build thread is inspiring, and you should do a write-up. One thing going into swap that requires more parts and modification, you really want to approach it with some type of a budget in mind. There's all kinds of parts, and prefab swap parts available, but if you go out and buy them all, you would be spending alot of money. I think a good write-up would also help a bunch of ratsun stay with in their low budgets. Thanks Quote Link to comment
datto510 Posted October 9, 2010 Report Share Posted October 9, 2010 Why don't you read through some of your favorite build threads and take notes on a piece of paper regarding the mods you like, parts you like, shortcuts, etc, etc... You can learn a lot from other peoples mistakes that are already documented on the forum. The info is already here, you just gotta look for it! Quote Link to comment
Jester Posted October 12, 2010 Report Share Posted October 12, 2010 Indy510, Thanks for the list of available links. Those will make a good start for someone to do some great reading. I like to read through other guys build threads as well to find ideas and parts needed. The problem is you get other peoples side line stories in the middle of 20 page thread on how they installed their SR/KA/whatever. Reading through all the BS to get the little stuff that really matters is the bitch. Not that it's for nothing, but, it would be nice if someone with the know, on one of their basic swaps, could do a pictorial walk through. Just something as basic as getting the motor sat in correctly, wiring it to the necessary sensors and such. I would love to do a single cam KA in my wagon. Simple, more power and mpg. It's just the wiring that scares the hell out of me. I HATE WIRING!! Quote Link to comment
djlotus Posted October 12, 2010 Report Share Posted October 12, 2010 Well thanks to Ice's writeup on doing the wiring it is damn simple. I don't like to do wiring and I was able to pull that part off. Quote Link to comment
hang_510 Posted October 12, 2010 Report Share Posted October 12, 2010 You can learn a lot from other peoples mistakes that are already documented Lesson 1. if you dont, you WILL repeat them. take video/pics so others will learn :rolleyes: There's all kinds of parts, and prefab swap parts available, but if you go out and buy them all, you would be spending alot of money. I think a good write-up would also help a bunch of ratsun stay with in their low budgets. Lesson 2. its not a cheap swap. cheap swaps are not good, good swaps are not cheap. Quote Link to comment
dvaet Posted February 7, 2011 Report Share Posted February 7, 2011 hey guys im swaping a ka24de into my 510 and im using my 510 master cylinder with the ka24de slave cylinder. does any one know where i can get the hose to conect these two parts? i only ask on this topic because i think it might be the same. i dont want to thread jack so you can pm me. Quote Link to comment
philcas1987 Posted February 7, 2011 Report Share Posted February 7, 2011 Use the 240sx one. But I think both would work. Give it a try!!! Quote Link to comment
DISLEXICDIME Posted February 7, 2011 Report Share Posted February 7, 2011 I think the reason no one has done a write up is because once you have the engine slid up under the car it is self explanitory you can see what need's to be done. Quote Link to comment
dvaet Posted February 7, 2011 Report Share Posted February 7, 2011 i know what to do i just dont know where to find the right hose. is thier some sort of adapter i can buy to conect the 510 master to the ka slave? Quote Link to comment
NCRmtrsprts510 Posted February 8, 2011 Report Share Posted February 8, 2011 Indy you forgot to post a CA build thread... Quote Link to comment
Laecaon Posted February 8, 2011 Report Share Posted February 8, 2011 i know what to do i just dont know where to find the right hose. is thier some sort of adapter i can buy to conect the 510 master to the ka slave? custom hose! I dont know, but I dont think it is that hard to get a custom hose made. Quote Link to comment
dvaet Posted February 8, 2011 Report Share Posted February 8, 2011 oh okay, thank you Laeceon. Quote Link to comment
