DanielC Posted January 10, 2008 Report Share Posted January 10, 2008 I am using a L-18 block in my PL-521. The PCV hose is bad, it needs to be replaced. I have hoses from an L-16 engine, but the crankcase end on the hoses i have are too big for the pipe coming out of the block. This is a JDM L-18 engine, if that makes any difference. Quote Link to comment
banzai510(hainz) Posted January 10, 2008 Report Share Posted January 10, 2008 daniel What I did with my L18(as with L20s) on my truck is that I cut the metal tube from block where it comes UP out of the block at a 90angle then I took a spare L16 tube and cut it to size and pounded it on the L18 90deg angle tube. As the L16 tube seems bigger. Then I just used the stock L16 PCV hoses. Quote Link to comment
