bluebird4200 Posted August 18, 2015 Report Share Posted August 18, 2015 Tach wire up: S14 KA24DE On the front of the distributor is a 2-wire plug. This is the coil. One of those wires is black with red. Cut this wire,and connect in series with the tach. BAM!I tried doing this today and it did not work! It works. By the way, the factory 510 tech responds really slowly to revs...30 year old technology right? Quote Link to comment
Zonargx Posted May 9, 2021 Report Share Posted May 9, 2021 What do you mean by connect in series? conect the red and back wire mention to the yellow red from tack Quote Link to comment
Zonargx Posted May 9, 2021 Report Share Posted May 9, 2021 (edited) On 10/7/2010 at 8:28 AM, compression said: Tach wire up: S14 KA24DE On the front of the distributor is a 2-wire plug. This is the coil. One of those wires is black with red. Cut this wire, and connect in series with the tach. BAM! It works. By the way, the factory 510 tech responds really slowly to revs...30 year old technology right? I’m not to familiar with wiring up so I need help I’m trying to wire up an aftermarket tack on an s14 ka swap in a truck. The yellow red Signal doesn’t work. what you mention was cut the red black wire set that wire to the tach then from there put the yellow red wires on it too? I kinda need this dumbed down a bit for me to get it Edited May 9, 2021 by Zonargx Quote Link to comment
