Javin Posted May 23, 2011 Report Share Posted May 23, 2011 That pic of the dually is AWESOME! I want a boat now :( I think the GF would kill me. I dont even have a place to put it.<_< Quote Link to comment
Steroid Posted June 5, 2011 Report Share Posted June 5, 2011 Memorial Day dual L-20-B boating action ! ! ! The sound of both boats going up river is INCREDIBLE ! ! ! Other than the mild water being added to the exhaust for very minor sound deadning, these both sound like open headers on 2 trucks going by ! ! ! ! UNREAL ! ! ! :cool: Quote Link to comment
Master-O-Turbonics Posted June 21, 2011 Report Share Posted June 21, 2011 Did they ever build a boat with an A series motor? What would be required to build a boat driveline off of an A14 like what is in my 81 210? Quote Link to comment
Pacific coast Datsun Posted June 21, 2011 Report Share Posted June 21, 2011 Did they ever build a boat with an A series motor? What would be required to build a boat driveline off of an A14 like what is in my 81 210? Not sure if an A series motor was ever used but other than changing the motor mounts on the boat i dont see why you couldnt. Ill get a pic of the back of the motor where it goes into the jet so you can see how it's done. The Datsun boats used a Castoldi jet & Ive seen one use a Hamilton jet as well. Quote Link to comment
Steroid Posted September 17, 2011 Report Share Posted September 17, 2011 These photos were taken off of Craigslist. This boat is currently for sale in Fresno, CA. It has a lot of similarities to Mine such as trim plates, gas tank and other smaller things that I have noticed. I wonder if Conqueror made them in blue?? Quote Link to comment
Steroid Posted September 17, 2011 Report Share Posted September 17, 2011 OOPS!!!! Forgot to add this!!!! http://fresno.craigslist.org/boa/2575332988.html Quote Link to comment
89rodknocker Posted November 8, 2011 Report Share Posted November 8, 2011 Looks like that boat is gone. If you come accross another pm me. Quote Link to comment
fivetenzen Posted November 9, 2011 Report Share Posted November 9, 2011 Looks like that boat is gone. If you come accross another pm me. I just bought one up here in Marysville CA - but it has a closed bow - more like a speed boat. But has an L20B - and it runs - needs some work but for 500 bucks - It will be fun to get going - But didn't get your in Fresno Quote Link to comment
fivetenzen Posted November 9, 2011 Report Share Posted November 9, 2011 Here is a picture of the new found Datsun Sundance I just bought - ok can't figure out how to post them http://s613.photobucket.com/albums/tt211/fivetenzen/Datsun%20Powered%20Sundance%20Jet%20Boat/ Quote Link to comment
Steroid Posted November 10, 2011 Report Share Posted November 10, 2011 There You go!!! I have a theory on this boat. Hulls and top sections are laid with 2 different molds. The bottom is seperate and looks exactly like Mine and Mark's hulls. The top section with the closed bow and dash might have been another option that Conqueror sold. Just pick which top the buyer wanted and graft it to the bottom hull. They are connected on most boats together where the aluminum strip with the black plastic covering runs all along the side. One other thing..... Check by sanding on the engine block where the engine ID number is. Does it match Your hull number? Mark's and Mine do. There should be a Conqueror Marine VIN plate/builder's plate installed on the inside side railing. Also, You should see Conqueror cast in the manifold. Did You get a title and if so what year does it show that it was built? ENJOY!!!! Quote Link to comment
fivetenzen Posted November 11, 2011 Report Share Posted November 11, 2011 There You go!!! I have a theory on this boat. Hulls and top sections are laid with 2 different molds. The bottom is seperate and looks exactly like Mine and Mark's hulls. The top section with the closed bow and dash might have been another option that Conqueror sold. Just pick which top the buyer wanted and graft it to the bottom hull. They are connected on most boats together where the aluminum strip with the black plastic covering runs all along the side. One other thing..... Check by sanding on the engine block where the engine ID number is. Does it match Your hull number? Mark's and Mine do. There should be a Conqueror Marine VIN plate/builder's plate installed on the inside side railing. Also, You should see Conqueror cast in the manifold. Did You get a title and if so what year does it show that it was built? ENJOY!!!! Quote Link to comment
fivetenzen Posted November 11, 2011 Report Share Posted November 11, 2011 I think you are right on the model - just sell what the people ask for - just change the top. I did check the vin - yes it matches like you said - the eng # -with the hull. i do have the paper work title for boat and trailer - 1975 boat model. So now how the H#!! do you change the oil without making a huge mess? Not that it would be to hard to pull the engine but really ? But have some work to do but hoping I will take some time and get it on the water this spring. I will get it on the water and then take the time to trick it out - paint and polish & powder coat everything. Steve Quote Link to comment
DanielC Posted November 11, 2011 Report Share Posted November 11, 2011 Boats are commonly made with a separate deck and hull. Quite often, boat companies put an open bow deck or a closed bow deck on top of the same hull. It is just a "shoebox" type fit, and after fitting the two parts together, and screwing them, a rub rail hides the joint. Quote Link to comment
Ooph! Posted November 12, 2011 Report Share Posted November 12, 2011 So now how the H#!! do you change the oil without making a huge mess? http://www.harborfre...pump-66418.html This or something like it, the hose gets fed down the dipstick tube. Really glad you bought it I was about to call and feed my addiction to projects I can never finish. Quote Link to comment
fivetenzen Posted November 13, 2011 Report Share Posted November 13, 2011 http://www.harborfre...pump-66418.html This or something like it, the hose gets fed down the dipstick tube. Really glad you bought it I was about to call and feed my addiction to projects I can never finish. Oh Yes - I have some of those - like 5 or 6 dozen :) Did you look at the Boat ? Quote Link to comment
Ooph! Posted November 13, 2011 Report Share Posted November 13, 2011 Oh Yes - I have some of those - like 5 or 6 dozen :) Did you look at the Boat ? No I knew better, I have too many projects already it would just end up sitting. Quote Link to comment
Steroid Posted June 30, 2012 Report Share Posted June 30, 2012 FOR SALE ! ! ! http://www.ablboats.com/87824 Quote Link to comment
peanutbuttercups Posted June 30, 2012 Report Share Posted June 30, 2012 rod of rods parts has 3-4 of em, if anyone is serious about a purchase B.O.A.T. = break out another thousand It's a cool boat. Can it pull a wakeboard if not, What's the point? Quote Link to comment
Rays74 Posted June 30, 2012 Report Share Posted June 30, 2012 Thanks for the link, Mike.........I never realized they used the L motor in those :) Doesn't surprize though seeing how reliable it would be with just the barest of maint :thumbup: Quote Link to comment
Z chopper Posted July 3, 2012 Report Share Posted July 3, 2012 now if one ever shows up in BC well in Western Canada for sale I am sure there will be a scrabble to see who gets it fiirst Quote Link to comment
Pacific coast Datsun Posted July 12, 2012 Report Share Posted July 12, 2012 I cant believe the yellow / white boat has not been sold yet ! Btw Steroid has located another Sundance boat...thats 12 we know of still around. 1 Quote Link to comment
Steroid Posted December 1, 2012 Report Share Posted December 1, 2012 Well, I guess now I am collecting boats ! ! ! Mark found another Sundance a few months ago here in Bullhead City. The crazy thing is it was only 3 blocks away from My barn and sitting behind two Z cars (that I have DEFINATELY seen many times). He inquired about it and checked it out. I went over a few days later and it "might be" for sale the owner said. He must have needed CHRISTmas money because this week I saw Him out in His yard and asked again. Yes was the answer. So within an hour it was headed to My place. He did say twice that it would start right up (Yeah, right). Mark came over today and sure enough, the man was right, IT FIRED ! ! We squirted oil down each cylinder, cleaned the sparkplugs, made a few other small repairs and first try, it started ! ! So now the thought of 3 boats running up the river next summer sounds almost too incredible 40 years after they were built ! ! I have to get registration done and purchase new trailer tires then dunk it in at the Laughlin, NV. launch and see if the jet works. Stay tuned ! ! Quote Link to comment
Pacific coast Datsun Posted December 2, 2012 Report Share Posted December 2, 2012 Mike..it was fun wrenching on the "new" boat today. A big part of the story is that this boat sat untouched for at least 10 years in the AZ sun & within 2 hours we had it running. We should have some pix up soon ! Quote Link to comment
Steroid Posted December 2, 2012 Report Share Posted December 2, 2012 Yes, Mark, Thank You ! ! Not only is it fun saving another part of history but as well comparing it to what We have already found and know about. We feel this boat has been "re-motored" but one significant find is the original wiring loom and gauge locations. Both Mark and My boats have been rewired and We had no idea where "mystery" wires had ran at one time. This boat has a very simple loom that We will be carefully tracing and logging. With this in mind both of Our other boats can now be easily rewired and wires not needed removed. This boat also has never had cleats installed, as is Mine. I cann't imagine a boat without cleats to tie it up on a dock, etc., but it appears they were not sold with cleats or night running lights. Very interesting. I am still hoping that one day a dealers brochure will surface that can answer questions but this boat has answered a few. Also, all 3 of the "Bullhead boats" have different trailers. I cann't figure that mystery out. The trailer on the yellow "Bakersfield" boat (above for sale) has a trailer that looks exactly like Mine, but the way the boats are secured are different. Maybe His is more correct due to the blue/yellow California license plate dating back possibly to when it was sold new. As more photos surface maybe in time these questions will be answered. The only other way is to either find a person that was employed at Conqueror or a non changed one owner boat that is exactly the way it was as sold. It is very cool though to find all these years later pieces of Datsun history. Quote Link to comment
Steroid Posted January 9, 2013 Report Share Posted January 9, 2013 ATTN: ANOTHER BOAT FOUND ! ! ! The crazy thing is it is only about 1/4 mile from the last (above) find ! ! It has been behind a fence for 15 years until being pulled out last week. It is in as good a shape as My yellow boat if not in some cases better. The hatch is missing but last month's find could provide one. Quote Link to comment
