Datsun b210 sedan Louvers
Ozomatli
  • Replies 17
my B210 had them but it was the Coupe (hatchback)
I never seen nor heard of sedan louvers.
In Australia they have Venetian Blinds for the sedan. But they fit inside the rear window, not outside like our louvers.
Any chance you know where i can get some for my hatchback 210 1980?
You could take the louvres off a Z and convert them to your coupe. :thumbup:
I have a 1980 210 Sedan. I think it would be a little trickier to install them on a sedan cause the Coupes Come with the brackets(which is up top on the roof) that open up the back Trunk/Window at the same time.
I've seen a 79 RX7 at my local junk yard which has the Rear Louver, I'll see if I can stop down one of these days and see how much they want for it.
You can make your own louvres for a sedan, go to Home Depot, and have Home Depot cut them to size. Installing the necessary brackets would be the challenge. I'm thinking you would want the louvre to follow the angle of the glass and attach the louvres and fabricate brackets accordingly. My B210 is running good right now. The clutch is weak but still grabs. My next project won't be louvres until after I replace my clutch. :rolleyes:
I'll be interested to see what you Ratsun brains invent. :D
Found this and I was right. Both datsun and toyota share the same rear window Louvers. A bit Pricey for something thats made of plastic I think, but will look cool :cool:
http://www.sfxperformance.com/parts/AST1234.htm]
These are for the B210 Sedan's which will also fit Toyota's
http://www.sfxperformance.com/mmy/1980/Nissan/210/parts/Louvers/search
These are for the 210 Sedans
