67411sss Posted September 19, 2010 Report Share Posted September 19, 2010 Desperately need a drive shaft for my '77 5 speed, Anyone got one lying around in the portland area? I have some stuff i could trade... Rory Quote Link to comment
datzenmike Posted September 19, 2010 Report Share Posted September 19, 2010 If you have a 620 you should update your profile so I know if a std cab, KC or long box. If you have a KC then a 4 speed KC or long box drive shaft should work. If you have a standard cab short wheelbase truck then only a short wheelbase 4 speed drive shaft will work. Did I make any sense??? Quote Link to comment
67411sss Posted September 19, 2010 Author Report Share Posted September 19, 2010 Done. so a kc drive shaft will work with the long box?. The one i have is to long so i'm guessing it's a 4 speed. Quote Link to comment
datzenmike Posted September 19, 2010 Report Share Posted September 19, 2010 The KC and the long box have the same wheel base so the 4 speed drive shaft should fit either. The 4 speed and the 5 speed are the same length. Quote Link to comment
